Exporting the Resource List
You can export all physical resources in the current DeC and the list of ECSs running in the resource pool to a local directory in .xlsx format. This file records the names, IDs, and resource usage of physical servers, as well as the names and IDs, specifications, private IP addresses, and EIPs of ECSs.
- Log in to the DeC console.
- Switch to the target region where DeC is enabled.
- Click the name of the desired DeC. The Dedicated Computing Cluster page appears. Figure 1 Clicking the DeC name
- Click the desired DCC resource pool. The DCC resource pool details page appears. You can view all physical servers you have been applied for in the physical server list. Figure 2 DCC resource pool
- Click Export above the physical server list to export information about all physical servers in the resource pool. Figure 3 Exporting the physical server list
