Updated on 2025-11-21 GMT+08:00
Expanding DCC Resources
If the DCC resources you have obtained cannot meet your demands, you can expand DCC resources.
- Log in to the DeC console.
- Click the region name in the upper left corner and select the required region.
- On the DeC page, click DCC resource pool.
The Dedicated Computing Cluster page is displayed.
- In the upper right corner, click Apply for Expansion.
The Apply for Resources page is displayed.
- Set the number of required servers and the usage duration. Figure 1 Applying for resources
- Click Next.
- Confirm the configuration and make a payment.
- After the payment is complete, wait for 1 to 2 minutes. Then you can view the purchased resources in the DCC resource pool.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
