Updated on 2025-11-21 GMT+08:00
Querying the DeC Information
You can view DeCs you have enabled in different regions. You can also view information about basic service resources, such as DCCs and ECSs, in a specific DeC.
Querying DeCs in all Regions
- Log in to the DeC console.
- Click the region name in the upper left corner to view the DeCs you have enabled in all regions.
Querying DeCs in a Specified Region
- Click the region name in the upper left corner and select the required region.
Querying Information About a DCC
- Switch to the DeC page by following the instructions provided in Querying DeCs in a Specified Region.
- Click the name of your desired DeC to view the monitoring information about DCC resource pools and the resources in the DeC, such as ECSs. Figure 1 Clicking the DeC name
Figure 2 DCC resource pool
You can view the following information on this page:
- Resource pool type: host type (host specifications), for example, General-computing (dec.s3)
- Physical resource specifications in the format of Number of CPU cores@CPU frequency / Memory size | AZ, for example, 64vCPUs@3.0GHz / 136GB | AZ1
- Physical Servers: specifies the number of physical servers.
- ECSs: specifies the number of ECSs.
- CPU Allocation Rate
- Total: specifies the total number of CPU cores of all physical servers in the cluster.
- In-use: specifies the number of used CPU cores.
- Not used: specifies the number of unused CPU cores.
- Memory Allocation Rate
- Total: specifies the total physical memory capacity of all the ECSs on physical servers.
- In-use: specifies the used memory.
- Not used: specifies the unused memory.
- Click the DCC resource pool to go to the resource pool details page. In the physical server list, view all obtained physical servers. You can also click a physical server name to view all ECSs created on the physical server. Figure 3 Physical server list
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
