Updated on 2025-11-21 GMT+08:00
Applying for DCC Resources
You can apply for DCC resources after you have enabled your DeC.
- Log in to the DeC console.
- Switch to the target region where DeC is enabled.
- Click the name of the desired DeC. The Dedicated Computing Cluster page appears. Figure 1 Clicking the DeC name
- In the upper right corner, click Buy DCC Resource Pool. On the displayed page, set the number of required servers and select the usage duration. Figure 2 Purchasing resources
- Click Next.
- Confirm the configuration and make a payment.
- After the payment is complete, wait for 1 to 2 minutes. Then you can view the purchased resources in the DCC resource pool.
