Updated on 2026-07-07 GMT+08:00
Discovery Dictionary Classification Configuration
The discovery dictionary classification is used for organizing the dictionary repository.
Adding dictionary category
  1. Logging in to the Database Operations and Maintenance Management System using the sysadmin system administrator account.
  2. In the left navigation bar, select Rule Management> Discover Dictionary to view the classification information of the discovered dictionary library.
  3. The right side of the page defaults to displaying the dictionary information list for the first dictionary category.
  4. Click the Add Dictionary Type button to open the new dictionary category page.
    Figure 1 Adding dictionary type
  5. Enter the dictionary type name and remarks.
    Table 1 Parameter escription for adding a new discovery dictionary category
    Dictionary Type
    Dictionary category name. (Required)
    Notes
    Function description.
  6. Click OK.
Related Operations
You may perform the following operations on the Discovery Dictionary Library page as needed subsequently:
  • Search: In the dictionary classification search area, enter the dictionary classification name to quickly filter the specified dictionary classification information.
  • Edit: Select the Dictionary Library Category, click the Pencil icon to open the Edit Dictionary Type page. Modify the configuration as needed, then click OK.
  • Delete: Select the dictionary category and click the Trash icon to delete the dictionary category information.
    Delete a dictionary category will cascade delete all dictionary information under that category.
