Help Center/ Database Security Service/ User Guide/ Database Security O&M/ Series 2/ System Function Configuration and Example Use Cases/ Quick Usage Guide/ Policy Application Process
Updated on 2026-09-24 GMT+08:00
The database O&M management system supports configuration and application of various policies to implement data-level access control. The policy application process is shown in Figure 1.
- The system administrator adds data assets and performs the corresponding configurations. For details, see O&M Asset Management.
- Set up protection policies. Policy management supports comprehensive security configuration, including: field desensitization, fuzzy matching desensitization, SQL blocking, row access control, SQL substitution, table name substitution, allowlist/denylist, and access audit policies. For details, see Security Control-Policy Management.
- Select the policy to enable and apply it. For details, see Security Control-Policy Management.
- In subsequent operations, you can view records of policy matches in the audit log. For details, see Policy Matching Audit.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
