Unsubscribing from an Instance
You can manually unsubscribe from an instance.
Constraints and Limitations
The Status of the target audit instance is Running and the Billing Mode is Yearly/Monthly.
- Select a region, click
, and choose . The Dashboard page is displayed. - In the navigation tree on the left, choose Instances.
- Click in the Operation column of the target instance.
- In the displayed dialog box, confirm the unsubscription information and click Yes to initiate the unsubscription process. After unsubscription, the target instance will not be displayed in the database audit instance list.
After the instance is unsubscribed, the database information, audit configuration information, and audit data added to the target instance will be cleared and cannot be restored.
