Help Center/ Database Security Service/ User Guide/ Database Audit/ Managing Database Audit Instances/ Restarting an Instance
Updated on 2026-07-07 GMT+08:00
You can manually restart a database audit instance.
It takes 1 to 3 minutes to restart an instance. During this period, database audit is stopped.
The Status of the target audit instance is Running.
- Log in to the DBSS console.
- Click
in the upper left corner on the displayed page and select a region. - In the navigation tree on the left, choose Instances.
- Click in the Operation column of the target instance.
- In the displayed dialog box, confirm the restart information. If the information is correct, click Yes. After the instance is restarted, check whether Status of the target instance is Running. If yes, the instance is restarted successfully.
References
- You can manually enable a database audit instance. For details, see Starting an Instance.
- You can manually disable a database audit instance. For details, see Disabling an Instance.
- You can manually enable or modify auto-renewal for database audit instances. For details, see Enabling or Modifying Auto Renewal.
- You can manually unsubscribe from a database audit instance. For details, see Unsubscribing from an Instance.
- You can manually release a database audit instance. For details, see Releasing an Instance.
- You can delete idle instances. For details, see Deleting an Instance.
- You can manually upgrade a database audit instance. For details, see Upgrading the Instance Version.
- You can add tags to database audit instances. For details, see Managing Instance Tags.
- Database audit instances support instance alarm handling. For details, see Handling Instance Alarm Information.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
