Updated on 2025-11-27 GMT+08:00
Process Overview
Context
Database audit supports auditing user-installed databases on ECS/BMS as well as RDS databases on Huawei Cloud.
Auditing Databases Without Agents
Databases of some types and versions can be audited without using agents, as shown in Table 1.
Table 1 Agent-free relational databases
Type
Supported Edition
All editions are supported by default.
RDS for SQLServer
RDS for MySQL
  • 5.6 (5.6.51.1 or later)
  • 5.7 (5.7.29.2 or later)
  • 8.0 (8.0.20.3 or later)
  • 8.2.0.100 or later
PostgreSQL
NOTICE:
If the size of an SQL statement exceeds 4 KB, the SQL statement will be truncated during auditing. As a result, the SQL statement is incomplete.
  • 14 (14.4 or later)
  • 13 (13.6 or later)
  • 12 (12.10 or later)
  • 11 (11.15 or later)
  • 9.6 (9.6.24 or later)
  • 9.5 (9.5.25 or later)
RDS for MariaDB
  • DBSS without agents is easy to configure and use, but the following functions are not supported:
    • Successful and failed login sessions cannot be counted.
    • The port number of the client for accessing the database cannot be obtained.
  • GaussDB(DWS) has the permission control policy for the log audit function. Only Huawei Cloud accounts and users with the Security Administrator permission can enable or disable the DWS database audit function.
Figure 1 Agent-free auditing process
Table 2 Procedure for quickly configuring database audit
Step
Configuration
Adding a Database
After purchasing DBSS, you need to add the database to be audited to the instance.
2
Enabling Database Audit
Enable database audit and connect the added database to the database audit instance.
3
Viewing the Audit Results
By default, database audit complies with a full audit rule, which is used to audit all databases that are connected to the database audit instance. You can view the audit result on the database audit page.
NOTICE:
You can set database audit rules as required. For details, see Adding Audit Scope.
