Updated on 2025-11-27 GMT+08:00
Configuring a Data Masking Allowlist
You can add an allowlist on the Allowlist page by configuring Database Username, IP Range, Start Time, and End Date. The relationship between the parameters is AND. If multiple parameters are configured, only those who meet all conditions are added to the allowlist. Users in the allowlist can view the unmasked plaintext data.
  1. Log in to a database encryption and access control instance as the sysadmin user.
  2. In the navigation pane on the left, choose Dynamic Data Mask > Data Masking Policy.
  3. Choose Data Type > Asset Name.
    Figure 1 Data source
  4. In the masking rule list, locate the target data source and click Allowlist Rule.
  5. On the Allowlist page, click Add Allowlist.
  6. Configure the parameters in the displayed Add Allowlist dialog box. Table 1 describes the parameters.
    Table 1 Adding an allowlist
    Data Source
    Data source name
    Database Username
    Database username to be added to the allowlist
    IP Range
    IP addresses to be added to the allowlist
    Authorization Start Time
    Time when the allowlist starts to take effect
    Authorization End Time
    Time when the allowlist stops to take effect
    Allowlist Rule
    • All Rules: All masking rules are added to the allowlist.
    • Specify Rules: Only specified rules are added to the allowlist.
    Figure 2 Adding an allowlist
  7. Click Save.
