Updated on 2026-07-07 GMT+08:00
Simulated Decryption Test
Before configuring a decryption task, you are advised to perform a simulated decryption test to verify the decryption function.
The table to be decrypted has been encrypted in the encryption task, that is, Configuring an Encryption Task has been completed.
  1. Log in to a database encryption and access control instance as the sysadmin user.
  2. In the navigation tree, choose Service Test > Simulation Test.
  3. Click Add Decryption Test.
  4. In the displayed dialog box, configure the test target.
    Figure 1 Adding a decryption test
  5. Click Save.
    After the test is complete, you can view the test result in the list and click Details to view the completion status of each node in the decryption process.
  6. After the test is complete, click Delete to delete the simulated decryption test.
    If a decryption task needs to be configured after the test, delete the simulated decryption test first.
