Managing Instance Tags
You can add tags to database audit instances for easy management. This section describes how to add a new tag or existing tag to an instance, delete a tag from an instance, and search for instances by tag.
The database audit instance is in the Running state.
Constraints and Limitations
Up to 50 tags can be added to each DB instance.
Adding a New Tag to an Instance
- Log in to the DBSS console.
- Click
in the upper left corner on the displayed page and select a region. - In the navigation tree on the left, choose Instances.
- Click the name of an instance. On the displayed page, click the Tag tab.
- Click Add Tag in the upper left corner. In the dialog box that is displayed, enter the tag key and tag value. Figure 1 Adding a tag
You can add multiple tags to an instance in the dialog box.
- Click OK.
Selecting an Existing Tag for an Instance
- Click
- Click Add Tag in the upper left corner. In the dialog box that is displayed, select an existing tag key and a value. Figure 2 Adding a tag
- Click OK.
Edit a Tag
- Click
- Click Edit in the Operation column of a tag. In the displayed dialog box, edit the tag value. Figure 3 Edit a tag
- Click OK.
Deleting a Tag
- Click
- Click Delete in the Operation column of a tag. In the displayed dialog box, enter DELETE and click OK. Figure 4 Deleting a tag
A tag cannot be deleted from multiple instances at a time. You can only delete one tag from one instance.
Searching for Instances by Tag
- Click
- In the search box above the instance list, select a tag key and a value to filter the instances with the specified tag.
References
- You can manually enable a database audit instance. For details, see Starting an Instance.
- You can manually disable a database audit instance. For details, see Disabling an Instance.
- You can manually restart a database audit instance. For details, see Restarting an Instance.
- You can manually enable or modify auto-renewal for database audit instances. For details, see Enabling or Modifying Auto Renewal.
- You can manually unsubscribe from a database audit instance. For details, see Unsubscribing from an Instance.
- You can manually release a database audit instance. For details, see Releasing an Instance.
- You can delete idle instances. For details, see Deleting an Instance.
- You can manually upgrade a database audit instance. For details, see Upgrading the Instance Version.
- Database audit instances support instance alarm handling. For details, see Handling Instance Alarm Information.
