DBSS Monitored Metrics
This section describes monitored metrics reported by DBSS to Cloud Eye as well as their namespaces and dimensions. You can use console or APIs provided by Cloud Eye to query the metrics of the monitored objects and alarms generated for DBSS.
Namespace
SYS.DBSS
A namespace is an abstract collection of resources and objects. Multiple namespaces can be created in a single cluster with the data isolated from each other. This enables namespaces to share the same cluster services without affecting each other.
Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Number System |
Monitored Object |
Monitoring Interval (Raw Data) |
cpu_util |
CPU Usage |
CPU consumed by the monitored object Unit: % Collection method: 100% minus idle CPU usage percentage |
0 to 100% Value type: Float |
N/A |
Database audit instance |
1 minute |
mem_util |
Memory Usage |
Memory usage of the monitored object Unit: % Collection method: 100% minus idle memory percentage |
N/A |
1 minute |
disk_util |
Disk usage |
Disk usage of the monitored object Unit: % Collection method: 100% minus idle disk space percentage |
N/A |
1 minute |
hx_process_status |
Protected Instance Process Status |
The process status of a protected instance.
This protected instance is no longer maintained. |
0/1
N/A |
N/A |
1 minute |
hx_port_stats |
Protected Instance Port Status |
The port status of a protected instance.
0/1
N/A |
N/A |
1 minute |
hx_proxy_num |
Protected Instance Agents |
The number of agents of a protected instance.
≥0 |
Count |
N/A |
1 minute |
hx_proxy_status |
Protected Instance Agent Status |
The agent status of a protected instance.
0/1
N/A |
N/A |
1 minute |
hx_qps |
Queries per Second |
The number of queries per second on the instance.
≥0 |
Count/s |
N/A |
1 minute |
hx_rps |
Requests per Second |
The number of requests per second on the instance.
≥0 |
Count/s |
N/A |
1 minute |
hx_active_connections_num |
Protected Instance Active Connections |
The number of active connections of a protected instance.
≥0 |
Count |
N/A |
1 minute |
