Handling Instance Alarm Information
After purchasing and enabling a database audit instance, you can view the database audit alarms on the DBSS console. This section describes how to confirm and delete the alarms after handling them. It also describes how to perform backup for an alarm of the type Ransomware prevention rules.
- The database audit instance is in the Running state.
- For details about how to enable database audit, see Enable Database Audit.
- Set alarm notification by referring to Configuring Alarm Notifications.
- Log in to the DBSS console.
- Click
in the upper left corner on the displayed page and select a region. - In the navigation tree on the left, choose Instances.
- Click the name of an instance. Click the tab. The alarm monitoring page is displayed. For more information, see Table 1.
- To confirm an alarm, click Confirm in the Operation column of the alarm. The alarm status changes to Confirmed. Figure 1 Confirming an alarm
You can select multiple alarms to be confirmed and click Batch Confirm to batch confirm alarms.
Figure 2 Confirming alarms in batches
- If an alarm has been handled, you can click Delete in the Operation column of the row that contains the alarm. In the dialog box that is displayed, click DELETE and click OK. Figure 3 Deleting an alarm
- If the alarm type of an alarm is Ransomware prevention rules, locate the row that contains the alarm and click the database backup button in the Operation column. For details, see Creating a Manual Backup.
Table 1 Alarm parameters Parameter
Time
Time when an alarm occurred.
Type
Alarm type. The options are as follows:
- Audit traffic exceeds threshold
- CPU exceptions
- Memory exceptions
- Disk exceptions
- Insufficient audit log storage
- Log backup to OBS failed
- Agent exceptions
- Risky operations
Alarm Risk Severity
Risk severity of an alarm. The options are as follows:
- High
- Moderate
- Low
Cleared
Time when an alarm is cleared
Confirmed Or Not
Confirmation status of an alarm.
Description of an alarm
Operation
Operations supported by alarms, including:
- Confirm
- Delete
- Back up to database
References
- How Do I View All Alarms in Database Audit?
- You can enable, disable, restart, unsubscribe from, release, and delete database audit instances. For details, see Configuring an Instance.
- You can manually enable or modify auto-renewal for a database audit instance. For details, see Enabling or Modifying Auto Renewal.
- You can manually upgrade the version of a database audit instance. For details, see Upgrading the Instance Version.
- You can add tags to database audit instances. For details, see Managing Instance Tags.
