Enabling or Modifying Auto Renewal
You can manually enable or modify auto-renewal for database audit instances. You can enable auto-renewal to automatically renew DBSS before it expires. This prevents resources from being deleted in case you forget to renew a subscription.
If you have enabled auto-renewal but no longer wish to automatically renew the subscription, you can disable it before the auto-renewal date (7 days before the expiry date by default) to avoid unexpected expenditures.
Constraints and Limitations
- The Pay-per-use mode is not supported. The Billing Mode of the target audit instance must be Yearly/Monthly.
- Auto-renewal can be enabled only for instances that have not enabled auto-renewal.
- Auto-renewal can be modified only for instances that have enabled auto-renewal.
- Log in to the DBSS console.
- Click
in the upper left corner on the displayed page and select a region. - In the navigation tree on the left, choose Instances.
- Perform renewal operations.
- Auto-renewal not enabled
- Click in the Operation column of the target DB instance.
- In the displayed dialog box, confirm the instance information and click Yes. The Enable Auto-Renewal page is displayed.
- Select the renewal duration. If you select Preset Auto-renewals, click Unlimited or Custom.
- Confirm the information and click OK to enable auto-renewal. Return to the Instances page. Billing Mode is displayed as Yearly/Monthly (Auto-Renew).
- Auto-renewal enabled
- In the displayed dialog box, confirm the instance information and click Yes. The Modify Auto-Renewal page is displayed.
- Select a renewal method.
- Auto-renewal upon expiration: Select the auto-renewal duration. You can also set the number of auto-renewals. You can click Unlimited or Custom.
- Manual renewal: Disable auto-renewal. You need to manually renew the subscription every month.
- Confirm the information and click OK.
References
- You can manually enable a database audit instance. For details, see Starting an Instance.
- You can manually disable a database audit instance. For details, see Disabling an Instance.
- You can manually restart a database audit instance. For details, see Restarting an Instance.
- You can manually unsubscribe from a database audit instance. For details, see Unsubscribing from an Instance.
- You can manually release a database audit instance. For details, see Releasing an Instance.
- You can delete idle instances. For details, see Deleting an Instance.
- You can manually upgrade a database audit instance. For details, see Upgrading the Instance Version.
- You can add tags to database audit instances. For details, see Managing Instance Tags.
- Database audit instances support instance alarm handling. For details, see Handling Instance Alarm Information.
