Configuring a Job for Synchronizing Data from PostgreSQL to DWS
Supported Source and Destination Database Versions
Source Database |
Destination Database |
PostgreSQL database of version 9.4, 9.5, 9.6, 10, 11, 12, 13, 14, 15, or 16 |
DWS cluster of version 8.1.3, 8.2.0, or a later version, except DWS 3.0 |
Database Account Permissions
Before you use DataArts Migration for data synchronization, ensure that the source and destination database accounts meet the requirements in the following table. The required account permissions vary depending on the synchronization task type.
Type |
Required Permissions |
Source database account |
Destination database account |
The destination database account must have the following permissions for each table in the database: INSERT, SELECT, UPDATE, DELETE, CONNECT, and CREATE. |
- You are advised to create independent database accounts for DataArts Migration task connections to prevent task failures caused by password modification.
- After changing the account passwords for the source or destination databases, modify the connection information in Management Center as soon as possible to prevent automatic retries after a task failure. Automatic retries will lock the database accounts.
Supported Synchronization Objects
The following table lists the objects that can be synchronized using different links in DataArts Migration.
Type |
Note |
Synchronization objects |
Important Notes
In addition to the constraints on supported data sources and versions, connection account permissions, and synchronization objects, you also need to pay attention to the notes in the following table.
Type |
Restriction |
Database |
Usage |
General:
Full synchronization phase: During task startup and full data synchronization, do not perform DDL operations on the source database. Otherwise, the task may fail. Incremental synchronization phase:
Troubleshooting: If any problem occurs during task creation, startup, full synchronization, incremental synchronization, or completion, rectify the fault by referring to FAQs. |
Other |
This section uses real-time synchronization from PostgreSQL to DWS as an example to describe how to configure a real-time data migration job. Before that, ensure that you have read the instructions described in Performing a Check Before Using a Real-Time Job and completed all the preparations.
- Create a real-time migration job by following the instructions in Creating a Real-Time Migration Job and go to the job configuration page.
- Select the data connection type. Select PostgreSQL for Source and DWS for Destination.
Figure 1 Selecting the data connection type
- Select a job type. The default migration type is Real-time. The migration scenarios include Entire DB and Database/Table partition.
Figure 2 Setting the migration job type
- Configure network resources. Select the created PostgreSQL and DWS data connections and the migration resource group for which the network connection has been configured.
Figure 3 Selecting data connections and a migration resource group
If no data connection is available, click Create to go to the Manage Data Connections page of the Management Center console and click Create Data Connection to create a connection. For details, see Configuring DataArts Studio Data Connection Parameters.
If no migration resource group is available, click Create to create one. For details, see Buying a DataArts Migration Resource Group Incremental Package.
- Check the network connectivity. After the data connections and migration resource group are configured, perform the following operations to check the connectivity between the data sources and the migration resource group.
- Click Source Configuration. The system will test the connectivity of the entire migration job.
- Click Test in the source and destination and migration resource group.
If the network connectivity is abnormal, see How Do I Troubleshoot a Network Disconnection Between the Data Source and Resource Group?
- Configure source parameters.
Select the databases and tables to be synchronized based on the following table.
Table 5 Selecting the Kafka topics to be synchronized Synchronization Scenario
Configuration Method
Entire DB
Select the PostgreSQL databases and tables to be migrated.Figure 4 Selecting databases and tablesBoth databases and tables can be customized. You can select one database and one table, or multiple databases and tables.
Database/Table shard
Add a logical table.- Logical Table Name: Enter the name of the table to be written to DWS.
- Source Database Filter: You can enter a regular expression to filter all the database shards in the PostgreSQL instance to be written to the destination DWS aggregation table.
- Source Table Filter: You can enter a regular expression to filter all the table shards in the source database shard to be written to the destination DWS aggregation table.
Figure 5 Adding a logical tableYou can click Preview in the Operation column to preview an added logical table. When you preview a logical table, the more the source tables, the longer the waiting time.
Figure 6 Previewing the logical table - Configure destination parameters.
- Set Database and Table Matching Policy.
For details about the matching policy between source and destination databases and tables in each synchronization scenario, see the following table.
Table 6 Database and table matching policy Synchronization Scenario
Entire DB
- Schema Matching Policy
- Same name as the source database: Data will be synchronized to the DWS schema with the same name as the source PostgreSQL database.
- Custom: Data will be synchronized to the DWS schema you specify.
- Table Matching Policy
- Same name as the source table: Data will be synchronized to the DWS table with the same name as the source PostgreSQL table.
- Custom: Data will be synchronized to the DWS table you specify.
Figure 7 Database and table matching policy in the entire database migration scenarioNOTE:
When you customize a matching policy, you can use built-in variables #{source_db_name} and #{source_table_name} to identify the source database name and table name. The table matching policy must contain #{source_table_name}.
- Destination Database Name: Data will be synchronized to the specified DWS schema.
- Table Matching Policy: By default, the value is the same as the name of the logical table entered in the source configuration.
Figure 8 Database and table matching policy in the sharding scenario
- Configure DWS parameters.
For details, see the following table.
Figure 9 DWS parametersTable 7 DWS parameters Parameter
Default Value
Unit
Write Mode
UPSERT
N/A
- UPSERT MODE: batch update
- COPY MODE: DWS-dedicated high-performance batch import
Maximum Data Volume for Batch Write
50000
Count
Number of data records written to DWS in a batch. You can adjust the value based on the table data size and job memory usage.
Scheduled Batch Write Interval
3
Second
Interval at which data is written to DWS
Advanced Settings
N/A
N/A
Some advanced functions can be configured using parameters. For details, see DWS advanced parameters.
Table 8 DWS advanced parameters Parameter
Type
Default Value
Unit
sink.buffer-flush.max-size
int
512
MB
Maximum number of bytes in each batch of data written to DWS. You can adjust the value based on the memory and data size configured for the job.
sink.keyby.enable
boolean
true
N/A
Whether to enable data distribution. If this function is enabled in multi-concurrency scenarios, data can be distributed to different processes based on specific rules and written to the destination, which improves the write performance.
sink.keyby.mode
string
table
N/A
Data distribution mode. The following modes are available:
- pk: Data is distributed by primary key value.
- table: Data is distributed by table name.
- In multi-concurrency scenarios, if DDL is enabled, data can be distributed only by table name. Otherwise, data may be inconsistent.
- If there is no DDL, you can select pk, which improves the write performance in multi-concurrency scenarios.
sink.field.name.case-sensitive
boolean
true
N/A
Whether to enable case sensitivity for data synchronization. If this function is enabled, the database names, table names, and field names are case sensitive during data synchronization.
sink.verify.column-number
boolean
false
N/A
Whether to verify the number of data columns. By default, the link synchronizes data in the same-name mapping mode. The system does not check whether all columns are synchronized.
If this function is enabled and the number of columns at the source is different from that at the destination, the system determines that data is inconsistent. As a result, the job is abnormal.
sink.server.timezone
string
Local time zone
N/A
Session time zone specified for connecting to the destination database. The standard time zone format is supported, for example, UTC+08:00.
logical.delete.enabled
boolean
false
N/A
Whether to enable logical deletion. If this function is enabled, the destination must contain the deletion flag column. When data is deleted from the source database, the corresponding data in the destination database will not be deleted. Instead, the deletion flag column is set to true, indicating that the data is not contained at the source.
logical.delete.column
string
logical_is_deleted
N/A
Name of the logical deletion column. The default value is logical_is_deleted. You can customize the value.
- Refresh and check the mapping between the source and destination tables. In addition, you can modify table attributes, add additional fields, and use the automatic table creation capability to create tables in the destination DWS database.
Figure 10 Mapping between source and destination tables
- Edit additional fields: Click Additional Field in the Operation column to add custom fields to the destination DWS table. For a new table, you can add additional fields to the existing fields in the source table. You can customize the field name, select the field type, and enter the field value.
- Field Name: name of the new field in the destination DWS table
- Field Type: type of the new field in the destination DWS table
- (Optional) Field Type Length: length of the new field type in the destination DWS table
- Field Value: Value source of the new field in the destination DWS table
Table 9 Additional field value obtaining mode Type
Example
Constant
Digits, letters, and special characters are supported. Color emoticons may cause a job submission failure.
Built-in variable
- Source host IP address: source.host
- Source schema name: source.schema
- Source table name: source.table
- Destination schema name: target.schema
- Destination table name: target.table
Source table field
Any field in the source table
Do not change the name of the source table field when the job is running. Otherwise, the job may be abnormal.
UDF
- substring(#col, pos[, len]): obtains a substring of a specified length from the source column name. The substring range is [pos, pos+len).
- date_format(#col, time_format[, src_tz, dst_tz]): formats the source column name based on a specified time format. The time zone can be converted using src_tz and dst_tz.
- now([tz]): obtains the current time in a specified time zone.
- if(cond_exp, str1, str2): returns str1 if the condition expression cond_exp is met and returns str2 otherwise.
- concat(#col[, #str, ...]): concatenates multiple parameters, including source columns and strings.
- from_unixtime(#col[, time_format]): formats a Unix timestamp based on a specified time format.
- unix_timestamp(#col[, precision, time_format]): converts a time into a Unix timestamp of a specified time format and precision. time_format must be the same as that in the source data.
- Automatic table creation: Click Auto Table Creation to automatically create tables in the destination database based on the configured mapping policy. After the tables are created, Existing table is displayed for them.
Figure 11 Automatic table creation
- DataArts Migration supports only automatic table creation. You need to manually create databases and schemas at the destination before using this function.
- For details about the field type mapping for automatic table creation, see Field Type Mapping.
- Configure task parameters.
Table 10 Task parameters Parameter
Default Value
Execution Memory
Memory allocated for job execution, which automatically changes with the number of CPU cores
8GB
CPU Cores
Value range: 2 to 32
For each CPU core added, 4 GB execution memory and one concurrency are automatically added.
2
Maximum Concurrent Requests
Maximum number of jobs that can be concurrently executed. This parameter does not need to be configured and automatically changes with the number of CPU cores.
Auto Retry
Whether to enable automatic retry upon a job failure
No
Maximum Retries
This parameter is displayed when Auto Retry is set to Yes.
Retry Interval (Seconds)
120s
Write Dirty Data
Whether to record dirty data. By default, dirty data is not recorded. If there is a large amount of dirty data, the synchronization speed of the task is affected.
- No: Dirty data is not recorded. This is the default value.
Dirty data is not allowed. If dirty data is generated during the synchronization, the task fails and exits.
- Yes: Dirty data is allowed, that is, dirty data does not affect task execution.
When dirty data is allowed and its threshold is set:
- If the generated dirty data is within the threshold, the synchronization task ignores the dirty data (that is, the dirty data is not written to the destination) and is executed normally.
- If the generated dirty data exceeds the threshold, the synchronization task fails and exits.
Criteria for determining dirty data: Dirty data is meaningless to services, is in an invalid format, or is generated when the synchronization task encounters an error. If an exception occurs when a piece of data is written to the destination, this piece of data is dirty data. Therefore, data that fails to be written is classified as dirty data.
For example, if data of the VARCHAR type at the source is written to a destination column of the INT type, dirty data cannot be written to the migration destination due to improper conversion. When configuring a synchronization task, you can configure whether to write dirty data during the synchronization and configure the number of dirty data records (maximum number of error records allowed in a single partition) to ensure task running. That is, when the number of dirty data records exceeds the threshold, the task fails and exits.
No
Dirty Data Policy
This parameter is displayed when Write Dirty Data is set to Yes. The following policies are supported:
- Do not archive: Dirty data is only recorded in job logs, but not stored.
- Archive to OBS: Dirty data is stored in OBS and printed in job logs.
Do not archive
Write Dirty Data Link
This parameter is displayed when Dirty Data Policy is set to Archive to OBS.
Only links to OBS support dirty data writes.
N/A
Dirty Data Directory
OBS directory to which dirty data will be written
N/A
Dirty Data Threshold
This parameter is only displayed when Write Dirty Data is set to Yes.
You can set the dirty data threshold as required.
NOTE:- The dirty data threshold takes effect for each concurrency. For example, if the threshold is 100 and the concurrency is 3, the maximum number of dirty data records allowed by the job is 300.
- Value -1 indicates that the number of dirty data records is not limited.
100
Custom attributes
You can add custom attributes to modify some job parameters and enable some advanced functions. For details, see Job Performance Optimization.
N/A
- Submit and run the job.
After configuring the job, click Submit in the upper left corner to submit the job.
Figure 12 Submitting the jobAfter submitting the job, click Start on the job development page. In the displayed dialog box, set required parameters and click OK.
Figure 13 Starting the jobTable 11 Parameters for starting the job Parameter
Offset Parameter
- Incremental synchronization: Incremental data synchronization starts from a specified time point.
- Full and incremental synchronization: All data is synchronized first, and then incremental data is synchronized in real time.
- Monitor the job.
On the job development page, click Monitor to go to the Job Monitoring page. You can view the status and log of the job, and configure alarm rules for the job. For details, see Real-Time Migration Job O&M.
Figure 14 Monitoring the job
If the synchronization speed is too slow, rectify the fault by referring to Job Performance Optimization.
