Configuring a Job for Synchronizing Data from DMS for Kafka to OBS
Supported Source and Destination Database Versions
Source Database |
Destination Database |
Kafka cluster (2.7 and 3.x) |
N/A |
Database Account Permissions
Before you use DataArts Migration for data synchronization, ensure that the source and destination database accounts meet the requirements in the following table. The required account permissions vary depending on the synchronization task type.
Type |
Required Permissions |
Source database account |
When ciphertext access is enabled for DMS for Kafka, the account must have the permissions to publish and subscribe to topics. In other scenarios, there are no special permission requirements. |
Destination database account |
You must have the permissions to access, read objects from, and write objects to the destination OBS bucket. For details, see Differences Between OBS Permissions Control Methods. |
- You are advised to create independent database accounts for DataArts Migration task connections to prevent task failures caused by password modification.
- After changing the account passwords for the source or destination databases, modify the connection information in Management Center as soon as possible to prevent automatic retries after a task failure. Automatic retries will lock the database accounts.
Supported Synchronization Objects
The following table lists the objects that can be synchronized using different links in DataArts Migration.
Type |
Note |
Synchronization objects |
All Kafka messages can be synchronized, and message bodies in JSON or CSV format can be parsed. |
Important Notes
In addition to the constraints on supported data sources and versions, connection account permissions, and synchronization objects, you also need to pay attention to the notes in the following table.
Type |
Restriction |
Database |
Usage |
General: During real-time synchronization, the IP addresses, ports, accounts, and passwords cannot be changed. Incremental synchronization phase: In the entire database migration scenario, you need to increase the number of concurrent jobs based on the number of topic partitions to be synchronized. Otherwise, a memory overflow may occur. Troubleshooting: If any problem occurs during task creation, startup, full synchronization, incremental synchronization, or completion, rectify the fault by referring to FAQs. |
Other |
This section uses real-time synchronization from DMS for Kafka to OBS as an example to describe how to configure a real-time data migration job. Before that, ensure that you have read the instructions described in Check Before Use and completed all the preparations.
- Create a real-time migration job by following the instructions in Creating a Real-Time Migration Job and go to the job configuration page.
- Select the data connection type. Select DMS Kafka for Source and OBS for Destination.
Figure 1 Selecting the data connection type
- Select a job type. The default migration type is Real-time. The migration scenarios include Single table and Entire DB.
Figure 2 Setting the migration job type
- Configure network resources. Select the created DMS for Kafka and OBS data connections and the resource group for which the network connection has been configured.
Figure 3 Selecting data connections and a resource group
If no data connection is available, click Create to go to the Manage Data Connections page of the Management Center console and click Create Data Connection to create a connection. For details, see Configuring DataArts Studio Data Connection Parameters.
If no resource group is available, click Create to create one. For details, see Buying a DataArts Migration Resource Group Incremental Package.
- Check the network connectivity. After the data connections and resource group are configured, perform the following operations to check the connectivity between the data sources and the resource group.
- Click Source Configuration. The system will test the connectivity of the entire migration job.
- Click Test in the source and destination and resource group.
If the network connectivity is abnormal, see How Do I Troubleshoot the Disconnectivity Between a Data Source and Resource Group?
- Configure source parameters.
- Select the Kafka topics to be synchronized in different migration scenarios based on the following table.
Table 5 Selecting the Kafka topics to be synchronized Synchronization Scenario
Configuration Method
Single table
Enter a Kafka topic to be migrated.Figure 4 Entering a Kafka topicEntire DB
Select the Kafka topics to be migrated.Figure 5 Selecting Kafka topics - Data Format
Format of the message content in the source Kafka topic. DataArts Migration can process the following types of messages:
- JSON: Messages can be parsed in JSON format.
- CSV: Messages can be parsed using specified separators in CSV format.
- TEXT: The entire message is synchronized as text.
- Consumer Group ID
A consumer subscribes to a topic. A consumer group consists of one or more consumers. DataArts Migration allows you to specify the Kafka consumer group to which a consumption action belongs.
- Source Kafka Attributes
You can set Kafka attributes and add the properties. prefix. The job will automatically remove the prefix and transfer the attributes to the Kafka client. For details about the parameters, see the configuration descriptions in the official Apache Kafka documentation.
- Configure destination parameters.
Figure 6 Configuring destination OBS parameters
- File Storage Format
Format of the files to be written to OBS. Parquet, SequenceFile, and TextFile are supported.
- File Compression Mode
Compression mode of the data to be written to OBS files. By default, data is not compressed. The following compression modes are supported:
- Parquet format: UNCOMPRESSED or SNAPPY
- SequenceFile format: UNCOMPRESSED, SNAPPY, GZIP, LZ4, or BZIP2.
- TextFile format: UNCOMPRESSED
- OBS Path
Path for storing OBS files. You can enter the #{source_Topic_name} built-in variable so that topics at the source can be written to different paths. An example path is obs://bucket/dir/test.db/prefix_#{source_Topic_name}_suffix/.
- Global Advanced Settings
You can configure the parameters in the following table to enable some advanced functions.
Table 6 OBS advanced parameters Parameter
Type
Default Value
Unit
auto-compaction
boolean
false
N/A
Whether to compact merge files. Data is written to a temporary file first. This parameter specifies whether to compact the generated temporary files after the checkpoint is complete. Enabling this function reduces the number of small files in some scenarios, but greatly slows down the synchronization.
- Refresh the mapping between the source table and destination table. Click Edit Destination Field to check the fields to be written to the destination and configure partition fields as needed.
Figure 7 Mapping between source and destination tables
- Partition Field
After you configure partition fields, a partition directory is automatically generated when data is written to OBS. The directory name is in Partition field=Partition value format. In addition, the field selection sequence affects the partition level. For example, if par1 and par2 are selected as partition fields, par1 is a level-1 partition and par2 is a level-2 partition. A maximum of five levels of partitions are supported.
- Edit Destination Field
DataArts Migration automatically parses source messages based on the selected source message format and generates corresponding fields. You can customize the names, types, and values of the fields.
- Field Name: name of the field to be written to the destination OBS file. The name must contain at least one letter and can contain underscores (_) and hyphens (-), but cannot contain only digits.
- Field Type: type of the field to be written to the destination OBS file. The following types are supported: STRING, BOOLEAN, INTEGER, LONG, FLOAT, DOUBLE, SHORT, DECIMAL, DATE, and TIMESTAMP.
- Field Value: value source of the field to be written to the destination OBS file
Table 7 Destination field value obtaining mode Type
Value
Manually assigned value
Any character
Built-in variable
Kafka metadata, including six fields: __key__, __value__, __Topic__, __partition__, __offset__, and __timestamp__.
Source table field
Any field parsed from the source Kafka topic message
If the source Kafka message is in nested JSON format, this link can parse field values at different levels (including arrays whose subscript indexes start from 1).
The following is an example of the JSON content:
{ "col1": "1", "col2": "2", "level1": { "level2": [ { "level3": "test" } ] } }
You can obtain test using level1.level2[1].level3 and use it as the value of a field at the destination.
UDF
Flink built-in function used to transform data. The following are examples:
- CONCAT(CAST(NOW() as STRING), `col_name`)
- DATE_FORMAT(NOW(), 'yy')
Note that the field name must be enclosed in backquotes. For details about the built-in functions of Flink, see the official Flink documentation.
- Partition Field
- Configure task parameters.
Table 8 Task parameters Parameter
Default Value
Execution Memory
Memory allocated for job execution, which automatically changes with the number of CPU cores.
8 GB
CPU Cores
Value range: 2 to 32
For each CPU core added, 4 GB execution memory and one concurrency are automatically added.
2
Maximum Concurrent Requests
Maximum number of jobs that can be concurrently executed. This parameter does not need to be configured and automatically changes with the number of CPU cores.
Auto Retry
Whether to enable automatic retry upon a job failure
No
Maximum Retries
This parameter is displayed when Auto Retry is set to Yes.
Retry Interval (Seconds)
120
Write Dirty Data
Whether to record dirty data. By default, dirty data is not recorded. If there is a large amount of dirty data, the synchronization speed of the task is affected.
Whether dirty data can be written depends on the data connection.
- No: Dirty data is not recorded. This is the default value.
Dirty data is not allowed. If dirty data is generated during the synchronization, the task fails and exits.
- Yes: Dirty data is allowed, that is, dirty data does not affect task execution.
When dirty data is allowed and its threshold is set:
- If the generated dirty data is within the threshold, the synchronization task ignores the dirty data (that is, the dirty data is not written to the destination) and is executed normally.
- If the generated dirty data exceeds the threshold, the synchronization task fails and exits.
Criteria for determining dirty data: Dirty data is meaningless to services, is in an invalid format, or is generated when the synchronization task encounters an error. If an exception occurs when a piece of data is written to the destination, this piece of data is dirty data. Therefore, data that fails to be written is classified as dirty data.
For example, if data of the VARCHAR type at the source is written to a destination column of the INT type, dirty data cannot be written to the migration destination due to improper conversion. When configuring a synchronization task, you can configure whether to write dirty data during the synchronization and configure the number of dirty data records (maximum number of error records allowed in a single partition) to ensure task running. That is, when the number of dirty data records exceeds the threshold, the task fails and exits.
No
Dirty Data Policy
This parameter is displayed when Write Dirty Data is set to Yes. The following policies are supported:
- Do not archive: Dirty data is only recorded in job logs, but not stored.
- Archive to OBS: Dirty data is stored in OBS and printed in job logs.
Do not archive
Write Dirty Data Link
This parameter is displayed when Dirty Data Policy is set to Archive to OBS.
Dirty data can only be written to OBS links.
N/A
Dirty Data Directory
OBS directory to which dirty data will be written
N/A
Dirty Data Threshold
This parameter is only displayed when Write Dirty Data is set to Yes.
You can set the dirty data threshold as required.
- The dirty data threshold takes effect only for each concurrency. For example, if the threshold is 100 and the concurrency is 3, the maximum number of dirty data records allowed by the job is 300.
- Value -1 indicates that the number of dirty data records is not limited.
100
Add Custom Attribute
You can add custom attributes to modify some job parameters and enable some advanced functions. For details, see Job Performance Optimization.
N/A
- Submit and run the job.
After configuring the job, click Submit in the upper left corner to submit the job.
Figure 8 Submitting the jobAfter submitting the job, click Start on the job development page. In the displayed dialog box, set required parameters and click OK.
Figure 9 Starting the jobTable 9 Parameters for starting the job Parameter
Offset Parameter
- Earliest: Data consumption starts from the earliest offset of the Kafka topic.
- Latest: Data consumption starts from the latest offset of the Kafka topic.
- Start/End time: Data consumption starts from the offset of the Kafka topic obtained based on the time.
Time
This parameter is required if Offset is set to Start/End time. It specifies the start time of synchronization.
If you set a time earlier than the earliest offset of Kafka messages, data consumption starts from the earliest offset by default.
- Monitor the job.
On the job development page, click Monitor to go to the Job Monitoring page. You can view the status and log of the job, and configure alarm rules for the job. For details, see Real-Time Migration Job O&M.
Figure 10 Monitoring the job
If the synchronization speed is too slow, rectify the fault by referring to Job Performance Optimization.
