Rest Client Connection Parameters
Parameter | Mandatory | Description |
Data Connection Type | Yes | The value is fixed at Rest Client. |
Name | Yes | Name of the data connection to create. Data connection names can contain a maximum of 100 characters. They can contain only letters, digits, underscores (_), and hyphens (-). |
Description | No | A description which can help identify the data connection more easily. It can contain a maximum of 100 characters. |
Tag | No | Attribute of the data connection to create. Tags make management easier. NOTE: The tag name can contain only letters, digits, and underscores (_) and cannot start with an underscore (_) or contain more than 100 characters. |
Applicable Modules | Yes | Select the modules for which this connection is available. The connection can be used in the selected modules. NOTE:
Basic and Network Connectivity Configuration | ||
Connection address prefix | Yes | This parameter is displayed when DataArts Migration is selected for Applicable Modules. Prefix of the connection address. This prefix is automatically added when an API is called during a job test or execution. HTTPS supports only TLS 1.2. Example: https://xxx.com/prefix |
Default Header | Yes | This parameter is displayed when DataArts Migration is selected for Applicable Modules. It specifies the default header parameter. This header is carried when an API is called. Example: {"Content-Type":"application/json"} |
KMS encryption key | Yes | KMS key used to encrypt and decrypt data source authentication information. Select a default or custom key. NOTE:
Agent | Yes | This parameter is displayed when DataArts Migration is selected for Applicable Modules. DataArts Studio cannot directly connect to non-fully managed services. An agent is required for DataArts Studio to communicate with non-fully managed services. A CDM cluster can function as an agent. If no CDM cluster is available, create one by referring to Creating a CDM Cluster. |
Data Source Authentication and Other Function Configuration | ||
Rest auth type | Yes | Authentication method. The following options are available:
Username | No | This parameter is displayed when Rest auth type is BASIC_AUTH. You can use #username to obtain the value and transfer it in the body and header. |
Password | No | This parameter is displayed when Rest auth type is BASIC_AUTH. You can use #password to obtain the value and transfer it in the body and header. |
Token | No | This parameter is displayed when Rest auth type is TOKEN_AUTH. You can use #token to obtain the value and transfer it in the body and header. |
Auth request url | No | This parameter is displayed when Rest auth type is OAUTH_CODE_GRANT. This parameter is available when Rest auth type is set to Oauth 2.0 (Authorization Code). This API supports OAuth 2.0. Authentication credentials are used to obtain a token. Before testing connections and jobs, call this API to obtain the token. In addition, the location, name, and value acquisition mode of the token carried in subsequent APIs are defined in the authentication token. Example: https://xxx.com/auth/token |
Auth request method | No | This parameter is displayed when Rest auth type is OAUTH_CODE_GRANT. Authentication request method in OAuth 2.0 mode. The value can be GET or POST. This parameter is mandatory if Auth request url is set. Example: GET |
Auth request username | No | This parameter is displayed when Rest auth type is OAUTH_CODE_GRANT. This parameter is mandatory for the Oauth 2.0 mode. You can use #authUsername to obtain the value of this parameter and enter it in the authHeader or authbody parameter. |
Auth request password | No | This parameter is displayed when Rest auth type is OAUTH_CODE_GRANT. This parameter is mandatory for the Oauth 2.0 mode. You can use #authPassword to obtain the value of this parameter and enter it in the authHeader or authbody parameter. |
Auth request header | No | This parameter is displayed when Rest auth type is OAUTH_CODE_GRANT. Request header for the Oauth 2.0 mode. The authentication account and password can be obtained through #authUsername and #authPassword. Example: {"username": "#authUsername","password": "#authPassword","Content-Type":"application/json"} |
Auth request body | No | This parameter is displayed when Rest auth type is OAUTH_CODE_GRANT. Request body for the Oauth 2.0 mode. This parameter is unavailable when Auth request method is set to GET. The authentication account and password can be obtained through #authUsername and #authPassword. Example: {"username": "#authUsername","password": "#authPassword"} |
Auth request token | No | This parameter is displayed when Rest auth type is OAUTH_CODE_GRANT. Authentication token, which can be obtained from the response body of the authentication API and carried in the connection and job test. The token can only be placed in the header. The value contains a parameter name and a parameter value. The parameter value can be a SpEL expression. The following is an example: The authentication response body is as follows: { "code" : 200, "data" : { "access_token" : "DSFSDFWE87WE9089W9EW9ER898WER9W89ER8", "expired":1000 } } To obtain the value of access_token in Bearer <token> format, set the value of this parameter as follows: NAME: Authorization VALUE: 'Bearer ' + #response.data.access_token |
Auth request token expired | No | This parameter is displayed when Rest auth type is OAUTH_CODE_GRANT. Validity period of the authentication token, in seconds. The value can be an EL expression. The default value 0 indicates that the token is permanently valid. Example 1: 300 indicates that the validity period is 300 seconds. Example 2: #response.data.expired. Obtain the value of the expired attribute from the JSON string returned by the authentication API. The default unit is second. If the value is not of the int type, enter a validity period. |
