Updated on 2026-08-21 GMT+08:00
Apache Hive
DataArts Migration supports the main versions of open-source Apache-Hive, meeting your data synchronization requirements in various deployment environments.
Preparation and Constraints
  • Network requirements
    The Apache Hive data source can communicate with CDM. This ensures smooth data transmission. For details, see Enabling Network Connectivity.
  • Enabling access ports: When configuring the Apache Hive data source, ensure that the following ports have been enabled in the security group or network so that DataArts Migration can access MRS.
    Table 1 Service ports
    Service
    Port Type
    Port Number
    Usage
    Hive
    TCP
    10000
    JDBC/ODBC interface of HiveServer, which is used by DataArts Migration to submit SQL statements and obtain results
    Hive
    TCP
    9083
    Hive Metastore interface, which is used by HiveServer to obtain metadata such as databases, tables, and partitions
    HDFS
    TCP
    8020
    Remote Procedure Call (RPC) port for NameNode, which is used by the client to establish context of file systems and obtain block locations
    HDFS
    TCP
    9866
    Streaming port for DataNode to read and write table files (ORC/Parquet)
    Zookeeper
    TCP
    2181
    ZK quorum on which HA HiveServer/Metastore and HDFS NameNode HA depend
Supported Data Types
The following table lists supported Hive data types.
Category
Hive Data Type
Read
String
CHAR
VARCHAR
STRING
Integer
TINYINT
SMALLINT
INT
INTEGER
BIGINT
Floating point
FLOAT
DOUBLE
DECIMAL
Date/Time
TIMESTAMP
DATE
Boolean
BOOLEAN
Binary
BINARY
Complex type
ARRAY
MAP
STRUCT
x
UNIONTYPE
x
Supported Migration Scenarios
DataArts Migration supports the following modes for synchronizing on-premises data:
  • Single table synchronization
    DataArts Migration supports table/file synchronization in data ingestion into a data lake or data migration to the cloud.
  • Database and table shard synchronization
    DataArts Migration supports synchronization of data from multiple databases and tables in data ingestion into a data lake or data migration to the cloud.
  • Entire DB migration
    DataArts Migrations supports synchronization of data from an on-premises database in data ingestion into a data lake or data migration to the cloud.
Database and table shard synchronization and entire DB migration are not supported in all regions. The following table lists the supported Apache Hive migration scenarios.
Single Table Read
Single Table Write
Database/Table Shard Read
Database/Table Shard Write
Entire DB Read
Entire DB Write
Supported
x
x
Supported in some regions
Core Capabilities
  • Connection configuration
    Configuration Item
    Supported
    Kerberos authentication
    Kerberos authentication is used to access MRS clusters.
    Storage-compute decoupling
    The storage-compute decoupling architecture is supported, and data can be read from different Hive storage file systems, such as OBS and HDFS.
  • Read capabilities
    Configuration Item
    Supported
    Read mode
    JDBC/HDFS
    HDFS files can be read through JDBC or directly. JDBC is suitable for interactive query and can flexibly read data using SQL syntax. When there is a large amount of data, directly reading the data and skipping SQL parsing is more efficient.
    Shard concurrency
    Horizontal sharding and multi-thread concurrent extraction significantly improve the throughput and efficiency. Currently, files can be concurrently read only from the HDFS.
    Custom fields
    x
    You can add computed columns, constant columns, or masking functions for tasks to meet personalized service requirements. Currently, this function is not supported.
    Dirty data processing
    Abnormal data can be written to the dirty data bucket to prevent job failures caused by a small amount of abnormal data.
    Incremental read
    Incremental read can be read through partition filtering or SQL statements.
  • Write capabilities
    Configuration Item
    Supported
    Write mode
    Insert into/Insert overwrite
    Two write modes are supported: INSERT INTO and INSERT OVERWRITE. Insert into appends data to the target table, which is applicable to incremental data writing. Insert overwrite overwrites data in the target table or partition, which is applicable to full data update.
    Pre- and post-import processing
    Partitions can be cleared in truncate mode.
    x
    Abnormal data cannot be written to the dirty data bucket to prevent job failures caused by a small amount of abnormal data.
    Concurrent write
    Concurrent write can fully utilize cluster resources to improve the data write speed.
Creating a Data Source
Create a data source in Management Center. For details, see Configuring Data Connection Parameters.
Creating an Offline Data Migration Job
Create an Apache Hive migration job in DataArts Factory. For details, see Creating an Offline Processing Migration Job.
