Updated on 2025-09-09 GMT+08:00
Doris Connection Parameters
Table 1 MRS Doris connection
Mandatory
Data Connection Type
Yes
Doris is selected by default and cannot be changed.
Name
Yes
Name of the data connection to create. Data connection names can contain a maximum of 100 characters. They can contain only letters, digits, underscores (_), and hyphens (-).
No
A description which can help identify the data connection more easily. It can contain a maximum of 100 characters.
Tag
No
Attribute of the data connection to create. Tags make management easier.
The tag name can contain only letters, digits, and underscores (_) and cannot start with an underscore (_) or contain more than 100 characters.
Applicable Modules
Yes
Select the modules for which this connection is available.
  • When offline or real-time data migration jobs are enabled, you can select the DataArts Migration module. Then you can select this data connection when creating a data migration job in DataArts Factory.
  • You can use offline or real-time data migration jobs only after you apply for the whitelist membership. To use this feature, contact customer service or technical support.
Basic and Network Connectivity Configuration
Doris Type
Yes
You can select MRS Doris or CloudTable Doris.
MRS Cluster Name
Yes
This parameter is valid when Doris Type is set to MRS Doris. The Doris connection supports only MRS clusters of version 3.2.0 or later.
The name of the MRS cluster. Select an MRS cluster that Hive belongs to. Only MRS clusters are supported. A Hadoop cluster can be selected only after it is managed by MRS. All the MRS clusters with the same project ID and enterprise project are displayed.
  • When connecting to a component of the MRS cluster, you need to enable the port of the component in the outbound rule of the security group of the MRS cluster. For details about the port of each component, see Common Ports for MRS Cluster Services.
  • DataArts Studio does not support MRS clusters whose Kerberos encryption type is aes256-sha2,aes128-sha2, and only supports MRS clusters whose Kerberos encryption type is aes256-sha1,aes128-sha1.
If the connection fails after you select a cluster, check whether the MRS cluster can communicate with the CDM instance which functions as the agent. They can communicate with each other in the following scenarios:
  • If the CDM cluster in the DataArts Studio instance and the MRS cluster are in different regions, a public network or a dedicated connection is required. If the Internet is used for communication, ensure that an EIP has been bound to the CDM cluster, and the MRS cluster can access the Internet and the port has been enabled in the firewall rule.
  • If the CDM cluster in the DataArts Studio instance and the MRS cluster are in the same region, VPC, subnet, and security group, they can communicate with each other by default. If they are in the same VPC but in different subnets or security groups, you must configure routing rules and security group rules. For details about how to configure routing rules, see Configuring Routing Rules. For details about how to configure security group rules, see Configuring Security Group Rules.
  • The MRS cluster and the DataArts Studio workspace belong to the same enterprise project. If they do not, you can modify the enterprise project of the workspace.
If an agent is connected to multiple MRS clusters and one of the MRS clusters is deleted or abnormal, connections to the other MRS clusters will be affected. Therefore, you are advised to connect an agent to only one MRS cluster.
Frontend IP
Yes
IP address of the frontend node in the Doris cluster. Use commas (,) to separate multiple IP addresses, for example, 127.0.0.1,127.0.0.2.
To obtain them, perform the following operations:
  1. Log in to MRS FusionInsight Manager.
  2. Choose Cluster > Services > Doris > Instance to obtain the management IP address of the FE role.
MySQL protocol port
Yes
Port used by the Doris FE to query connections through the MySQL protocol. The default port is 9030.
To obtain it, perform the following operations:
  2. Choose Cluster > Services > Doris > Configurations > Basic Configurations, search for query_port, and view the port number.
KMS Key
Yes
KMS key used to encrypt and decrypt data source authentication information. Select a default or custom key.
  • When you use KMS for encryption through DataArts Studio or KPS for the first time, the default key dlf/default or kps/default is automatically generated. For more information about default keys, see What Is a Default Master Key?.
  • Only symmetric keys are supported. Asymmetric keys are not supported.
Agent
Yes
MRS is not a fully managed service and cannot be directly connected to DataArts Studio. A CDM cluster can provide an agent for DataArts Studio to communicate with non-fully-managed services. Therefore, you need to select a CDM cluster when creating an MRS data connection. If no CDM cluster is available, create one first by referring to Creating a CDM Cluster.
As a network proxy, the CDM cluster must be able to communicate with the MRS cluster. To ensure network connectivity, the CDM cluster must be in the same region and AZ and use the same VPC and subnet as the MRS cluster. The security group rule must also allow the CDM cluster to communicate with the MRS cluster.
  • If you use the same CDM cluster as the agent for multiple connections to MRS clusters with Kerberos authentication enabled, jobs will fail. You are advised to plan multiple CDM clusters based on service requirements.
  • If a CDM cluster functions as the agent for a data connection in Management Center, the cluster supports a maximum of 200 concurrent active threads. If multiple data connections share an agent, a maximum of 200 SQL, Shell, and Python scripts submitted through the connections can run concurrently. Excess tasks will be queued. You are advised to plan multiple agents based on the workload.
Enable Https
No
Whether to enable SSL encrypted transmission for Doris. This function is enabled by default. Disable it if SSL is disabled at the source.
If HTTPS is enabled for the Doris cluster, this parameter is set to true. The default value is true.
Data Source Driver Configuration
Driver Name
Yes
Driver name. Currently, the MySQL JDBC driver is supported. The driver name is com.mysql.jdbc.Driver.
Driver Source
Yes
Select the source of the driver file.
Driver File Path
Yes
This parameter is mandatory when Driver file source is set to OBS path.
Path of the driver file in the OBS bucket. You need to download the .jar driver file from the corresponding official website and upload it to the OBS bucket.
MySQL driver: Obtain the driver from https://downloads.mysql.com/archives/c-j/. Version 5.1.48 or later is recommended. If the version is earlier than 5.1.48, error "The db user or password invalid" will be reported.
  • The OBS path of the driver file cannot contain Chinese characters.
  • For security purposes, the system checks the SHA512 value and byte size of the selected driver file. If the driver file is not in the allowed list, an error message will be displayed. You are advised to use the driver file of the recommended version or contact customer service or technical support.
  • To update the driver, you must restart the CDM cluster in DataArts Migration and then edit the data connection to upload the driver.
Driver File
Yes
This parameter is mandatory when Driver Source is set to Local file. Select a driver version that adapts to the database type.
Data Source Authentication and Other Function Configuration
Username
Yes
Username of the MRS or CloudTable cluster.
If a new MRS user is used for connection, you need to log in to Manager and change the initial password.
To create a data connection for an MRS security cluster, do not use user admin. The admin user is the default management page user and cannot be used as the authentication user of the security cluster. You can create an MRS user with a permanent password by referring to Creating a Kerberos Authentication User for an MRS Security Cluster. When creating an MRS data connection, set Username and Password to the new MRS username and password.
  • For clusters of MRS 3.1.0 or later, the user must at least have permissions of the Manager_viewer role to create data connections in Management Center. To perform database, table, and data operations on components, the user must also have user group permissions of the components.
  • For clusters earlier than MRS 3.1.0, the user must have permissions of the Manager_administrator or System_administrator role to create data connections in Management Center.
  • A user with only the Manager_tenant or Manager_auditor permission cannot create connections.
  • You are advised to set a user password that never expires to prevent connection failures and service loss caused by password expiration.
Password
Yes
It can also be the password for accessing the MRS or CloudTable cluster.
Data Integration Configuration
FE Port
Yes
HTTP port number of the FE in the Doris cluster. The default port number is 8030. If HTTPS is enabled, the default port number is 8050, which is used to write data using streamLoad.
Database Name
Yes
Name of the database to be connected
Fetch Size
No
Number of rows obtained by each request The default value is 1,000.
Commit Size
No
Number of rows submitted in a batch. The default value is 10,000.
Link Attributes
No
Click Add and set the attribute name and value. The value contains a maximum of 512 characters. You can click Delete to delete attributes.
The following are examples:
  • socketTimeout: JDBC connection timeout duration, in milliseconds
  • mysql.bool.type.transform: whether to parse tinyint(1) to a Boolean value during data reading from a MySQL database. The default value is true.
Reference Sign
No
Reference sign, for example, ".
Database enclosure character. For some databases, the value is case sensitive. Leave this parameter blank if no enclosure character is required.
Check Stream Load Connectivity
No
Whether to check Doris stream load connectivity. To write data using stream load, ensure that stream load connectivity is normal.
To create a data connection for an MRS security cluster, do not use user admin. The admin user is the default management page user and cannot be used as the authentication user of the security cluster. To create an MRS user, perform the following steps:
For clusters of MRS 3.x:
  1. Log in to MRS Manager as user admin.
  2. Choose System > Permission > Security Policy > Password Policy. Click Add Password Policy and add a policy under which the password never expires.
    • Set Password Policy Name to neverexp.
    • Set Password Validity Period (Days) to 0, indicating that the password never expires.
    • Set Password Expiration Notification (Days) to 0.
    • Retain the default values for other parameters.
  3. Choose System > Permission > User. On the page displayed, click Create to add a dedicated human-machine user as the Kerberos authentication user and set the password policy to neverexp. Select the user group superGroup for the user, and assign all roles to the user.
  4. Log in to Manager as the new user and change the initial password. Otherwise, the connection fails to be created.
  5. Synchronize IAM users.
    1. Log in to the MRS console.
    2. Choose Clusters > Active Clusters, select a running cluster, and click its name to go to its details page.
    3. In the Basic Information area of the Dashboard page, click Synchronize on the right side of IAM User Sync to synchronize IAM users.
      • If the status is Synchronized, skip this step.
      • When the policy of the user group to which the IAM user belongs changes from MRS ReadOnlyAccess to MRS CommonOperations, MRS FullAccess, or MRS Administrator, wait for 5 minutes until the new policy takes effect after the synchronization is complete because the SSSD (System Security Services Daemon) cache of cluster nodes needs time to be updated. Then, submit a job. Otherwise, the job may fail to be submitted.
      • When the policy of the user group to which the IAM user belongs changes from MRS CommonOperations, MRS FullAccess, or MRS Administrator to MRS ReadOnlyAccess, wait for 5 minutes until the new policy takes effect after the synchronization is complete because the SSSD cache of cluster nodes needs time to be updated.
For clusters of MRS 2.x or earlier:
  1. Log in to the MRS Manager as user admin.
  2. On FusionInsight Manager, choose System Settings and click Configure Password Policy to modify the password policy.
  3. Choose System > Manage User. On the page displayed, add a dedicated human-machine user as the Kerberos authentication user. Select the user group superGroup for the user, and assign all roles to the user.
    • For clusters of MRS 2.x or earlier, the user must have permissions of the Manager_administrator or System_administrator role to create data connections in Management Center.
  4. Log in to MRS Manager as the new user and change the initial password. Otherwise, the connection fails to be created.
