MRS Presto Connection Parameters
| Parameter | Mandatory | Description |
| Data Connection Type | Yes | MRS Presto is selected by default and cannot be changed. |
| Name | Yes | Name of the data connection to create. Data connection names can contain a maximum of 100 characters. They can contain only letters, digits, underscores (_), and hyphens (-). |
| Description | No | A description which can help identify the data connection more easily. It can contain a maximum of 100 characters. |
| Tag | No | Attribute of the data connection to create. Tags make management easier. NOTE: The tag name can contain only letters, digits, and underscores (_) and cannot start with an underscore (_) or contain more than 100 characters. |
| Applicable Modules | Yes | Select the modules for which this connection is available. |
| Basic and Network Connectivity Configuration | ||
| MRS Cluster Name | Yes | The name of the MRS cluster. Select an MRS cluster that Hive belongs to. Only MRS clusters are supported. A Hadoop cluster can be selected only after it is managed by MRS. All the MRS clusters with the same project ID and enterprise project are displayed. NOTE:
If the connection fails after you select a cluster, check whether the MRS cluster can communicate with the CDM instance which functions as the agent. They can communicate with each other in the following scenarios:
| Data Source Authentication and Other Function Configuration | ||
| Description | No | You can enter the description of the connection. |
