Updated on 2026-03-20 GMT+08:00
MRS Ranger Connection Parameters
Table 1 MRS Ranger connection
Mandatory
Data Connection Type
Yes
MRS Ranger is selected by default and cannot be changed.
Name
Yes
Name of the data connection to create. Data connection names can contain a maximum of 100 characters. They can contain only letters, digits, underscores (_), and hyphens (-).
No
A description which can help identify the data connection more easily. It can contain a maximum of 100 characters.
Tag
No
Attribute of the data connection to create. Tags make management easier.
The tag name can contain only letters, digits, and underscores (_) and cannot start with an underscore (_) or contain more than 100 characters.
Applicable Modules
Yes
Select the modules for which this connection is available.
Basic and Network Connectivity Configuration
Manual
Yes
Select the connection mode. If you do not need to access MRS clusters in other projects or enterprise projects, select Cluster Name Mode.
  • Cluster Name Mode: Select an existing cluster. You can only connect to an MRS cluster in the same project and enterprise project.
  • If you select Connection String Mode, you can set Manager IP and enable communication between this connection's agent (CDM cluster) and an MRS cluster in another project or enterprise project so that you can access the MRS cluster.
Manager IP
Yes
This parameter is mandatory when Connection String Mode is selected for Manual.
Set this parameter to the floating IP address of MRS Manager. Only MRS clusters are supported. A Hadoop cluster can be connected only after it is managed by MRS.
  • When connecting to a component of the MRS cluster, you need to enable the port of the component in the outbound rule of the security group of the MRS cluster. For details about the port of each component, see Common Ports for MRS Cluster Services.
  • DataArts Studio does not support MRS clusters whose Kerberos encryption type is aes256-sha2,aes128-sha2, and only supports MRS clusters whose Kerberos encryption type is aes256-sha1,aes128-sha1.
You can click Select next to the text box and select an MRS cluster in the same project and enterprise project. If you want to access an MRS cluster in another project or enterprise project, obtain and enter the floating IP address of MRS Manager and ensure that the connection's agent (CDM cluster) can communicate with the tenant-plane MRS cluster. To obtain the floating IP address of MRS Manager, log in to the active master node of the MRS cluster and run the ifconfig command. In the command output, the IP address of eth0:wsom is the floating IP address of MRS Manager. For details about how to log in to the master node of the MRS cluster, see Logging In to an ECS.
Enter multiple IP addresses based on the scenario in sequence and separate them with commas (,), for example, 127.0.0.1 or 127.0.0.1,127.0.0.2,127.0.0.3.
  • If you enter one IP address, enter the management-plane floating IP address of the MRS cluster.
  • If you enter three IP addresses, enter the IP address of the active node on the MRS cluster service plane, IP address of the standby node on the MRS cluster service plane, and the floating IP address of the MRS cluster management plane.
If the version of the CDM cluster selected as the agent is 2.9.3.300 or earlier, you can only create a connection to MRS Ranger in an MRS cluster in security mode.
To create a connection to MRS Ranger in an MRS cluster in non-security mode, ensure that the CDM cluster version is 2.10.0.300 or later, or contact customer service or technical support to upgrade the dlg-agent component in the CDM cluster.
MRS Cluster Name
Yes
This parameter is mandatory when Cluster Name Mode is selected for Manual.
The name of the MRS cluster. Select an MRS cluster that Hive belongs to. Only MRS clusters are supported. A Hadoop cluster can be selected only after it is managed by MRS. All the MRS clusters with the same project ID and enterprise project are displayed.
If the connection fails after you select a cluster, check whether the MRS cluster can communicate with the CDM instance which functions as the agent. They can communicate with each other in the following scenarios:
  • If the CDM cluster in the DataArts Studio instance and the MRS cluster are in different regions, a public network or a dedicated connection is required. If the Internet is used for communication, ensure that an EIP has been bound to the CDM cluster, and the MRS cluster can access the Internet and the port has been enabled in the firewall rule.
  • If the CDM cluster in the DataArts Studio instance and the MRS cluster are in the same region, VPC, subnet, and security group, they can communicate with each other by default. If they are in the same VPC but in different subnets or security groups, you must configure routing rules and security group rules. For details about how to configure routing rules, see Configuring Routing Rules. For details about how to configure security group rules, see Configuring Security Group Rules.
  • The MRS cluster and the DataArts Studio workspace belong to the same enterprise project. If they do not, you can modify the enterprise project of the workspace.
If an agent is connected to multiple MRS clusters and one of the MRS clusters is deleted or abnormal, connections to the other MRS clusters will be affected. Therefore, you are advised to connect an agent to only one MRS cluster.
IP Address
Yes
Management IP address of the RangerAdmin role of the MRS Ranger component. Separate multiple IP addresses with commas (,).
To obtain the port number, perform the following operations:
  1. Log in to MRS FusionInsight Manager.
  2. Choose Cluster > Services > Ranger > Instance to view the management IP address of the RangerAdmin role.
Port
Yes
Port number of the MRS Ranger instance.
  2. Choose Cluster > Services > Ranger > Configurations > Basic Configurations. For an MRS cluster in non-security mode, obtain the port corresponding to the ranger.service.http.port parameter. For an MRS cluster in security mode, obtain the port corresponding to the ranger.service.https.port parameter.
KMS encryption key
Yes
KMS key used to encrypt and decrypt data source authentication information. Select a default or custom key.
  • When you use KMS for encryption through DataArts Studio or KPS for the first time, the default key dlf/default or kps/default is automatically generated. For more information about default keys, see What Is a Default Master Key?.
  • Only symmetric keys are supported. Asymmetric keys are not supported.
Agent
Yes
MRS is not a fully managed service and cannot be directly connected to DataArts Studio. A CDM cluster can provide an agent for DataArts Studio to communicate with non-fully-managed services. Therefore, you need to select a CDM cluster when creating an MRS data connection. If no CDM cluster is available, create one first by referring to Creating a CDM Cluster.
As a network proxy, the CDM cluster must be able to communicate with the MRS cluster. To ensure network connectivity, the CDM cluster must be in the same region and AZ and use the same VPC and subnet as the MRS cluster. The security group rule must also allow the CDM cluster to communicate with the MRS cluster.
  • If you use the same CDM cluster as the agent for multiple connections to MRS clusters with Kerberos authentication enabled, jobs will fail. You are advised to plan multiple CDM clusters based on service requirements.
  • If a CDM cluster functions as the agent for a data connection in Management Center, the cluster supports a maximum of 200 concurrent active threads. If multiple data connections share an agent, a maximum of 200 SQL, Shell, and Python scripts submitted through the connections can run concurrently. Excess tasks will be queued. You are advised to plan multiple agents based on the workload.
Data Source Authentication and Other Function Configuration
Authentication Method
Yes
It specifies the authentication method used for accessing the MRS cluster. The following options are available:
  • SIMPLE: for non-security mode
  • KERBEROS: for security mode
Username
Yes
Username of the MRS cluster If a new MRS user is used for connection, you need to log in to Manager and change the initial password.
To create a data connection for an MRS security cluster, do not use user admin. The admin user is the default management page user and cannot be used as the authentication user of the security cluster. You can create an MRS user whose password never expires by referring to Creating a Kerberos Authentication User for an MRS Security Cluster. When creating an MRS data connection, set Username and Password to the new MRS username and password.
  • For clusters of MRS 3.1.0 or later, the user must at least have permissions of the Manager_viewer role to create data connections in Management Center. To perform database, table, and data operations on components, the user must also have user group permissions of the components.
  • For clusters earlier than MRS 3.1.0, the user must have permissions of the Manager_administrator or System_administrator role to create data connections in Management Center.
  • A user with only the Manager_tenant or Manager_auditor permission cannot create connections.
  • You are advised to set a user password that never expires to prevent connection failures and service loss caused by password expiration.
Password
Yes
Password for accessing the MRS cluster.
To create a data connection for an MRS security cluster, do not use user admin. The admin user is the default management page user and cannot be used as the authentication user of the security cluster. To create an MRS user, perform the following steps:
For clusters of MRS 3.x:
  1. Log in to MRS Manager as user admin.
  2. Choose System > Permission > Security Policy > Password Policy. Click Add Password Policy and add a policy under which the password never expires.
    • Set Password Policy Name to neverexp.
    • Set Password Validity Period (Days) to 0, indicating that the password never expires.
    • Set Password Expiration Notification (Days) to 0.
    • Retain the default values for other parameters.
  3. Choose System > Permission > User. On the page displayed, click Create to add a dedicated human-machine user as the Kerberos authentication user and set the password policy to neverexp. Select the user group superGroup for the user, and assign all roles to the user.
  4. Log in to Manager as the new user and change the initial password. Otherwise, the connection fails to be created.
  5. Synchronize IAM users.
    1. Log in to the MRS console.
    2. Choose Clusters > Active Clusters, select a running cluster, and click its name to go to its details page.
    3. In the Basic Information area of the Dashboard page, click Synchronize on the right side of IAM User Sync to synchronize IAM users.
      • If the status is Synchronized, skip this step.
      • When the policy of the user group to which the IAM user belongs changes from MRS ReadOnlyAccess to MRS CommonOperations, MRS FullAccess, or MRS Administrator, wait for 5 minutes until the new policy takes effect after the synchronization is complete because the SSSD (System Security Services Daemon) cache of cluster nodes needs time to be updated. Then, submit a job. Otherwise, the job may fail to be submitted.
      • When the policy of the user group to which the IAM user belongs changes from MRS CommonOperations, MRS FullAccess, or MRS Administrator to MRS ReadOnlyAccess, wait for 5 minutes until the new policy takes effect after the synchronization is complete because the SSSD cache of cluster nodes needs time to be updated.
For clusters of MRS 2.x or earlier:
  1. Log in to the MRS Manager as user admin.
  2. On FusionInsight Manager, choose System Settings and click Configure Password Policy to modify the password policy.
  3. Choose System > Manage User. On the page displayed, add a dedicated human-machine user as the Kerberos authentication user. Select the user group superGroup for the user, and assign all roles to the user.
    • For clusters of MRS 2.x or earlier, the user must have permissions of the Manager_administrator or System_administrator role to create data connections in Management Center.
  4. Log in to MRS Manager as the new user and change the initial password. Otherwise, the connection fails to be created.
