Managing the Permission Validity Period
If you need a permission only for a short period of time, you can manage its validity period.
If you are using the new version mode, you can manage the validity periods of permissions only in the enterprise version. If you are using the old version mode, you can perform these operations in the basic version or an advanced version.
This section describes how an applicant applies for short-term permissions (Applying for Short-term Permission), renews permissions (Renewing Permissions), and subscribes to permission expiration notifications (Subscribing to Permission Expiration Notifications), and how an administrator changes the permission validity period (Changing the Validity Period) and configures permission expiration notifications (Configuring Permission Expiration Notifications).
Notes and Constraints
- Only the DAYU Administrator, Tenant Administrator, and data security administrator can change the permission validity period, configure permission expiration notifications, and operate all notifications. Non-administrator users can operate their subscriptions, but cannot view or operate other users' subscriptions.
- Permission expiration notifications will be sent seven days before the permission expires. The time cannot be changed.
- Expired permissions will be revoked but retained for seven days before they are cleared.
- To configure the permission expiration notifications, you must grant the SMN FullAccess permission of the SMN service to the dlg_agency.
If a notification topic in DataArts Factory is used for expiration notifications, no notifications will be received because the subscriptions added in DataArts Factory have filtering policies. In this case, you must associate notifications with subscriptions apart from subscribing to notifications so that permission expiration notifications can be received.
- Subscriptions are associated with users through remarks. Subscriptions whose remarks are usernames are regarded as subscriptions of the corresponding users.
- The subscription list is associated a topic. If the topic is changed, you must reconfigure notifications.
- The configured endpoint information cannot be edited. If the phone number or email address changes, delete the endpoint, add it again, and request a subscription again.
- If the user group information for the expiration notification has changed, update the subscription policy so that the correct group information can be received in time.
- A notification is sent everyday for all the permissions that are about to expire. If there are too many permissions that are about to expire, those that will expire sooner will be displayed first. A notification can contain a maximum of 100 records or 200,000 bytes.
- Due to concurrency and SMN performance limitations, SMN notifications may be delayed for a few minutes.
When applying for a permission on the DataArts Security console or Data Map console, you can select the validity period of the permission. You can select a fixed validity period (starting from the application date) or customize the expiration time (24:00 on the expiration day). If you do not set this parameter, the permission will not expire.
After the application is approved, you have the permission within the validity period.
Figure 1 shows the page for applying for a short-term permission on the DataArts Security console.
You can apply for renewing the permissions that are about to expire if necessary. After the application is approved, the validity period will be extended to the new expiration time.
- On the DataArts Studio console, locate a workspace and click DataArts Security.
- In the navigation pane on the left, choose Access Permission Management > Permission Review. In the right pane, click the My Permissions tab.
- On the My Permissions page, view the permissions that you have obtained.
Schedule Job Count is only supported for Hive, Spark, and DLI tables, and is not supported for the inventory data of the jobs using EL expressions or simple variable sets.
Figure 2 My Permissions page
- Locate a permission and click Renewal in the Operation column to renew the permission, or select permissions and click Batch Renewal above the list to renew the permissions. You can select a fixed validity period (starting from the application date) or customize the expiration time (24:00 on the expiration day).Figure 3 Renewing permissions
- Click OK.
- Check the ticket approval status in the Permission Renewal Status column.
The administrator can review user permissions and adjust inappropriate validity periods of permissions so that permissions can be updated or revoked in a timely manner.
- In the navigation pane on the left, choose Access Permission Management > Permission Review. On the Permission Review page, click the Permission Revocation tab.
- On the Permission Revocation page, view the approved permissions in the current workspace.Figure 4 Permission Revocation page
- Locate a permission and click Change Validity Period in the Operation column to change the validity period of the permission, or select permissions and click Change Validity Period above the list to change the validity period of multiple permissions. You can select a fixed validity period (starting from the application date) or customize the expiration time (24:00 on the expiration day).Figure 5 Changing the validity period
- Click OK.
The administrator can configure the topic and time of the permission expiration notification. Users who have subscribed to the notifications will receive notifications seven days before a permission expires.
- In the navigation pane on the left, choose Access Permission Management > Permission Review. On the Permission Review page, click the Permission Notifications tab.
- On the Permission Notifications page, configure a permission expiration notification.
- Permission Expiration Notification Topic: Select an SMN topic.
- Permission Expiration Notification Time on Each Day: Select an hour for daily notification.
- Permission Expiration Notification Workspace Account Management Role: Select the workspace role that will send permission expiration notifications.
After configuring permission expiration notifications, subscribed users will receive notifications seven days before permissions expire.
- On the Permission Notifications page, the SMN endpoints that have subscribed to specific SMN topics are displayed in the subscription list. The usernames in the list correspond to subscription remarks. Applicants can only perform operations on subscriptions whose remarks are the same as usernames.
Figure 6 Subscribing to permission expiration notifications
- If there is no subscription corresponding to the current username, click Add Subscription to add a subscription. Table 1 lists the parameters. Click Request Confirmation in the Operation column to confirm the subscription. If the subscription status changes to Confirmed, the subscription is successful.
Table 1 Parameters for adding a subscription Parameter
Mandatory
SMN Protocol
Yes
Protocol through which notifications are received. You can select SMS, Email, or DingTalk chatbot.
SMN Endpoint
Yes
Endpoint information.
When SMN Protocol is set to DingTalk chatbot, obtain endpoint information by referring to How Does a DingTalk, Internal DingTalk, Lark, or WeCom Chatbot Obtain Subscription Endpoints?.
Key (Optional)
No
This parameter is available only when SMN Protocol is set to DingTalk chatbot. Obtain the key from the security settings of the DingTalk chatbot.
Keyword(Optional)
No
This parameter is available only when SMN Protocol is set to DingTalk chatbot. Select a keyword from the security settings of the DingTalk chatbot.
