Viewing Owners of Table Permissions (Table Permission View) (Advanced Feature)
DataArts Security allows you to view the permission list. You can view the workspace users, user groups, and roles (including workspace permission sets, permission sets, and roles) that have permissions to specified tables in the current instance.
In the new version mode, the table permission view is supported only in the enterprise version. In the old version mode, this function is supported in the basic version or an advanced version.
Notes and Constraints
- The Table-Role tab does not display the URL permission policies of MRS Hive with decoupled storage and compute.
- Permissions cannot be directly configured or revoked on the Table Permission View page.
- Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Security.
- In the navigation pane on the left, choose Data Security Operations > Table Permission View. Figure 1 Table Permission View page
- On the Table Permission View page, you can switch between tabs to view different types of owners of table permissions.
- Table-User tab page: displays the table permissions obtained for users in the current instance through authorization objects in the permission application and approval process by default. You can filter data source types and search for permissions by username, cluster name, database, or table name. For details about the permission application and approval process, see Applying for Permissions and Approving Permissions (Some Advanced Features).Figure 2 Table-User page
- Table-Role tab page: displays the table permissions granted to roles (including workspace permission sets, permission sets, and roles) in the current instance by default. You can filter data source types and search for permissions by role, cluster name, database, or table name.
For details about the process of granting permissions to workspace permission sets, permission sets, and roles, see Configuring Workspace Permission Sets, Configuring Permission Sets, or Configuring Roles.
Figure 3 Table-Role
- Table-UserGroup tab page: displays the table permissions obtained for user groups in the current instance through authorization objects in the permission application and approval process by default. You can filter data source types and search for permissions by user group, cluster name, database, or table name.
Figure 4 Table-UserGroup
