Managing Members
DataArts Security allows you to view the permissions of workspace members, and manage roles and permission sets.
- Permission sets or roles have been configured for members. For details, see Configuring Permission Sets or Configuring Roles.
- Only the DAYU Administrator, Tenant Administrator, data security administrator, or role or permission set administrator can add or delete roles or permission sets for members.
- Only common roles can be added or deleted for members. Managed roles are not supported.
- The permissions configured for members take effect only after roles or permission sets are successfully synchronized.
Viewing the Policy and Details
- Log in to the DataArts Studio console.
For details, see Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Security.
- In the navigation pane on the left, choose Access Permission Management > Member Management. Figure 1 Member Management page
- Locate a member and click Edit in the Operation column. In the displayed dialog box, add or delete roles or permission sets for the member to manage its permissions. Figure 2 Edit Role/Permission Set
- Click View Permission in the Operation column to view the basic information, permissions, and permission sources of a member. The resource content varies depending on the data source type and resource type.
Table 1 Resource content displayed for different resource and data source types Resource Type
Data Source Type
Resource Content
Data column
DLI, HIVE, DWS, and HETUENGINE
DWS: database.schema.table.column
DLI/HIVE: database.table.column
HETUENGINE:catalog.schema.table.column
Table
Schema
DWS and HETUENGINE
Database
DLI, HIVE and DWS
DLI/HIVE/DWS: database
Catalog
HETUENGINE
catalog
URL
HIVE
url
UDF (function)
HIVE
database.function
Logical cluster
DWS
logiccluster
