Updated on 2026-03-20 GMT+08:00
Developing a Python Job
This section describes how to develop and execute a Python job using DataArts Factory.
Preparing the Environment
  • ECS has been enabled and an ECS named ecs-dgc has been created.
    In this example, the ECS uses the CentOS 8.0 64bit with ARM (40 GB) public image and the Python environment. You can log in to the ECS and run the python command to check the Python environment.
  • You have enabled the DataArts Migration incremental package and created a CDM cluster named cdm-dlfpython. The cluster provides an agent for the DataArts Factory module to communicate with the ECS.
  • Ensure that the ECS can communicate with the CDM cluster, which depends on the following conditions:
    • If the CDM cluster and the ECS are in the same region, VPC, subnet, and security group, they can communicate with each other by default. If they are in the same VPC but in different subnets or security groups, you must configure routing rules and security group rules. For details about how to configure routing rules, see Configuring Routing Rules. For details about how to configure security group rules, see Configuring Security Group Rules.
    • If the CDM cluster and the ECS are in different regions, a public network or a dedicated connection is required for enabling communication between the CDM cluster and the cloud service. If the Internet is used for communication, ensure that an EIP has been bound to the CDM cluster, the host where the data source is located can access the Internet, and the port has been enabled in the firewall rules.
    • The ECS and the CDM cluster belong to the same enterprise project. If they do not, you can modify the enterprise project of the workspace.
  • Python nodes support script parameters and job parameters.
  • This section uses Python3 as an example.
Creating an ECS Data Connection
Before developing a Python script, you need to create a connection to the ECS.
  1. Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
  2. On the DataArts Studio console, locate a workspace and click Management Center.
  3. On the displayed Manage Data Connections page, click Create Data Connection.
  4. Configure parameters by referring to Table 1 and create a data connection named ecs.
    Table 1 Host Connection parameters
    Mandatory
    Data Connection Type
    Yes
    Host Connection is selected by default and cannot be changed.
    Name
    Yes
    Name of the data connection to create. Data connection names can contain a maximum of 100 characters. They can contain only letters, digits, underscores (_), and hyphens (-).
    No
    A description which can help identify the data connection more easily. It can contain a maximum of 100 characters.
    Tag
    No
    Attribute of the data connection to create. Tags make management easier.
    The tag name can contain only letters, digits, and underscores (_) and cannot start with an underscore (_) or contain more than 100 characters.
    Applicable Modules
    Yes
    Select the modules for which this connection is available.
    Basic and Network Connectivity Configuration
    Host Address
    Yes
    IP address of the Linux host
    For details, see Viewing Details About an ECS.
    Agent
    Yes
    CDM cluster used as an agent. If no CDM cluster is available, create one first by referring to Creating a CDM Cluster.
    • If a CDM cluster functions as the agent for a data connection in Management Center, the cluster supports a maximum of 200 concurrent active threads. If multiple data connections share an agent, a maximum of 200 SQL, Shell, and Python scripts submitted through the connections can run concurrently. Excess tasks will be queued. You are advised to plan multiple agents based on the workload.
    • When scheduling shell or Python scripts, the agent accesses the ECS. If shell and Python scripts are scheduled frequently, the ECS adds the private IP address of the agent to the blocklist. To ensure normal job scheduling, you are advised to use the root user of the ECS to add the private IP address bound to the agent (CDM cluster) to the /etc/hosts.allow file.
      For details about how to obtain the private IP address of the CDM cluster, see Viewing Cluster Information and Modifying Configurations.
    Port
    Yes
    SSH port number of the host.
    By default, port 22 is used to log in to a Linux host. If the port number has been changed, you can obtain the new port number from the port field in the /etc/ssh/sshd_config file.
    KMS encryption key
    Yes
    KMS key used to encrypt and decrypt data source authentication information. Select a default or custom key.
    • When you use KMS for encryption through DataArts Studio or KPS for the first time, the default key dlf/default or kps/default is automatically generated. For more information about default keys, see What Is a Default Master Key?.
    • Only symmetric keys are supported. Asymmetric keys are not supported.
    Data Source Authentication and Other Function Configuration
    Username
    Yes
    Username for logging in to the host
    Login Mode
    Yes
    Mode for logging in to the host
    • Key Pair
    • Password
    Key Pair
    Yes
    This parameter is available only when Login Mode is set to Key Pair.
    If Key Pair is the login mode of the host, you need to obtain the private key file, upload it to OBS, and select an OBS path.
    The uploaded private key must match the public key configured on the host. For details, see Application Scenarios for Using Key Pairs.
    Key Pair Password
    Yes
    If no password is set for the key pair, you do not need to set this parameter.
    Password
    Yes
    This parameter is available only when Login Mode is set to Password.
    If the login mode of the host is to use a password, enter a login password.
    Host Connection Description
    No
    Descriptive information about the host connection
    Figure 1 Creating a host connection
    The key parameters are as follows:
  5. Click Test to test connectivity of the data connection. If the test fails, the data connection cannot be created.
  6. After the test is successful, click OK to create the data connection.
Developing a Python Script
  1. Choose DataArts Factory > Develop Script and create a Python script named python_test.
    Figure 2 Creating a Python script
  2. Select a Python version (for example, Python 3) and host connection, and set input parameters as needed.
    The parameters will be transferred to the Python script when the script is executed. The parameters are separated by spaces, for example, Microsoft Oracle. The parameters must be referenced by the Python script. Otherwise, the parameters are invalid.
  3. Edit Python statements in the editor.
    This example defines a string template for saving company information and uses the template to output information about different companies.
    import sys
    Company_Name1=sys.argv[1]
    Company_Name2=sys.argv[2]
    template='No.:{:0>9s} \t CompanyName: {:s} \t Website: https://www.{:s}.com'
    context1=template.format('1',Company_Name1,Company_Name1.lower())
    context2=template.format('2',Company_Name2,Company_Name2.lower())
    print(context1)
    print(context2)
    • The script development area in Figure 3 is a temporary debugging area. After you close the script tab, the development area will be cleared.
    • Connection: Select the data connection created in Creating an ECS Data Connection.
    Figure 3 Editing the Python statements
  4. Click Save and then Submit.
  5. Click Execute to execute the Python statements.
  6. View the script execution result.
    Figure 4 Viewing the script execution result
Referencing the Python Script in a Job
  1. Create a job.
  2. Select a Python node and configure the node properties.
    Select the created Python script and set the node parameters. Set Script Parameters.
    The parameters will be transferred to the Python statement when the statement is executed. The parameters are separated by spaces, for example, Microsoft Oracle. The parameters must be referenced by the Python statement. Otherwise, the parameters are invalid.
    Figure 5 Configuring properties of the Python node
  3. Click Test and view the job running result.
    Figure 6 Checking the job execution result
  4. Click Save. The job configuration is complete.
  5. Click Submit. After a version is submitted, the job can be scheduled.
