Updated on 2025-09-09 GMT+08:00
Configuring Default Items
This section describes how to configure default items. You can perform the operations in this section only if you have the permissions of DAYU Administrator or Tenant Administrator. For details about how to configure permissions, see Creating an IAM User and Granting DataArts Studio Permissions.
Default configuration items are a set of parameters that can be configured by default in the system or software and can be used by all jobs or scripts in the current workspace. These items simplify operations, and can be used to centrally manage public parameters.
If a parameter is used by multiple jobs or scripts, you can use this parameter as a default configuration item. In this way, you do not need to set this parameter for each job or script. By using default configuration items, you can:
Improve configuration efficiency: You do not need to set the same parameter for each job or script.
Reduce maintenance costs: In a common service scenario, you only need to modify the default configuration items. The modifications can be automatically synchronized to all the jobs or scripts that use the configuration items.
Modifying some default configuration items may affect existing services. Jobs or scripts of existing services will be executed according to the modified default rules.
Table 1 Configuration items
Configuration Item
Affected Module
Whether Modification Affects Existing Services
Main Usage
Periodic Scheduling
Job scheduling
Yes
  • Policy for handling the current job when its dependency fails
  • Policy for handling the current job instance when its dependency stops
Multi-IF Policy
Job scheduling
Yes
Policy for executing nodes with multiple IF conditions
Hard and Soft Lock Policy
Script/Job development
No
Policy for grabbing the lock of a job or script
Script Variable Definition
Script development
Yes
Format definition of script variables. Two formats are available: ${} and ${dlf.}.
Data Export Policy
No
Policy for downloading or dumping the SQL execution result
  • All users
  • No user
  • Only workspace administrator
Disable Auto Node Name Change
Job Development
No
When a node in a DataArts Studio job is associated with a script or a job of another service, the node name does not change accordingly.
Default Settings for New Jobs
Job creation
No
Default type and mode of a new job, for example, a batch processing pipeline job
Use Simple Variable Set
Job development
Yes
A simple variable set provides a series of custom variables that automatically replace parameters during job scheduling.
Notification Policy for Jobs in Failure Ignored Status
O&M and scheduling
No
Notification type for jobs whose status is failure ignored
Retry Node upon Timeout
Job execution
Yes
Whether a node will be re-executed if it fails upon timeout
Exclude Waiting Time from Instance Timeout Duration
Job execution
Yes
If you select Yes, the waiting time before an instance starts running is excluded from the instance timeout duration.
Rules for Splitting MRS JAR Package Parameters
Job development
Yes
Rules for splitting string parameters (parameters enclosed by "") in the JAR packages of MRS MapReduce and MRS Spark operators
Synchronization of Job Version by Waiting Instance
O&M and scheduling
Yes
Whether a waiting instance synchronizes the latest job version when it runs
Execution Mode for Hive SQL and Spark SQL Statements
No
  • In OBS: The OBS path is returned to MRS.
  • In the request message body: The script content is returned to MRS.
PatchData Job Priority
O&M – PatchData
No
Priority of a PatchData job. If system resources are insufficient, computing resources are preferentially allocated to jobs with higher priorities. A larger value indicates a higher priority. Priorities can be set only for DLI SQL operators.
Historical Job Instance Cancellation Policy
O&M and scheduling
Yes
Days to wait before job instances are canceled. If the wait time of a job instance exceeds the value of this parameter, the instance will be canceled. The minimum value is 2, that is, a job instance can be canceled only after two days. The default value is 60 days.
Historical Job Instance Alarm Policy
O&M and scheduling
No
Days in which alarms can be reported for job instances.
The default value is 7, that is, alarms can be reported for the job instances created within the last seven days, but not for those created before that.
Job Alarm Notification Topic
Notification configuration
No
Topic used to send notifications by owner
Default Retry Policy upon Job Operator Failure
O&M and scheduling
Yes
Default policy for retrying a failed job operator
Generate Alarm Upon Job Retry Failure
O&M and scheduling
No
If you select All jobs, Real-time jobs, or Batch jobs, an alarm is generated each time a job fails to be retried.
If you select Disable, an alarm is generated only when the maximum number of retries has been reached for the job.
Automatic Script Name Transfer During Job Execution
Job development (job execution)
No
If this function is enabled, set mapreduce.job.name=Script name of the Hive SQL script is automatically transferred to MRS during job execution in the current workspace.
Job Dependency Rule
Job scheduling
No
Jobs can be depended on by jobs in other workspaces (requires the permission to query the job list in the workspace). All default roles in the workspace have this permission. Custom roles must have the job query permission in DataArts Factory.
Stopping Job Scheduling
Job scheduling
Yes
Whether to allow a job to stop scheduling when the job has downstream dependencies.
Script Execution History
No
Which script execution results are displayed
  • Myself: The script execution history for only myself is displayed.
  • All users: The script execution history for all users is displayed.
Identity for Job Tests
Job development (job test)
No
Identity for testing jobs.
  • Public agency or IAM account: A public agency or IAM account is used to execute jobs.
  • Personal account: The user who clicks Test is used to execute jobs.
SparkSqlJob/Script Default Template Configuration
Spark SQL script/job development
No
Whether any parameters can be set for Spark SQL jobs and scripts
HiveSqlJob/Script Default Template Configuration
No
Whether any parameters can be set for Hive SQL jobs and scripts
Job/Script Change Management
Job/Script import and export
No
Whether to enable job/script change management for the workspace
  • Yes: Events are recorded for job and script changes. All the changed jobs and scripts can be incrementally exported and imported by time.
  • No: No events are recorded for job and script changes. Only selected jobs and scripts can be exported and imported.
Log Open Mode
Viewing logs
No
Whether to open logs on a new tab or in a pop-up window
If No Tag Is Available
Job development
No
Whether tags can be created directly if no tag is available
Configuring Periodic Scheduling
  • To configure the default action on the current job when the job it depends on fails, perform the following operations:
    1. In the left navigation pane on the DataArts Factory console, choose Configuration > Configure.
    2. Choose Default Configuration.
      Three options are available. The default value is Terminate.
      • Suspend: The current job is suspended.
      • Continue: The current job continues to be executed.
      • Cancel: The current job is canceled.
    3. Click Save to save the settings. This parameter takes effect only for new jobs.
  • To configure the default action on the current job instance when the job it depends on is stopped, perform the following operations:
      Two options are available. The default value is Terminate.
      • Suspend: The current job instance is suspended.
      • Cancel: The current job instance is canceled.
Configuring the Multi-IF Policy
To configure the policy for executing nodes with multiple IF conditions, perform the following operations:
  1. In the navigation pane, choose Configuration > Specifications.
    The following two options are available:
    • OR: Nodes are executed if an IF condition is met.
    • AND: Nodes are executed if all IF conditions are met.
    For details, see Configuring the Policy for Executing a Node with Multiple IF Statements.
Configuring the Hard and Soft Lock Policy
The policy determines how you can grab the lock of a job or script. If you use a soft lock, you can grab the lock of a job or script regardless of whether you have the lock. If you use a hard lock, you can only unlock or grab the lock of a job or script for which you have the lock. Operations such as publish, execution, and scheduling are not restricted by locks.
You can configure the hard/soft policy based on your needs.
    The default policy is Soft Lock.
    • Soft lock: You can lock or unlock jobs or scripts, regardless of whether they are locked by others.
    • Hard Lock: You can lock jobs or scripts only after they have been unlocked by other users. The space administrator and the DAYU Administrator user can lock and unlock jobs or scripts without any limitations.
Configuring Script Variables
Variables of an SQL script can be in ${} or ${dlf.} format. You can configure either type as needed. The configured variable format applies to SQL scripts, SQL statements in jobs, single-node jobs, and environment variables.
  1. In the navigation pane, choose Configuration > Configure.
  2. Click Default Configuration and set Script Variable Definition.
    The default variable format is ${}.
    • ${}: Identify the definition of the ${} format in the script and parse the field as the variable name. For example, variable name xxx is identified from ${xxx}.
    • ${dlf.}: Identify the definition of the ${dlf.} format in the script and parse the dlf. field as the variable name. Other ${} format definitions are not recognized as variables. For example, variable name dlf.xxx is identified from ${dlf.xxx}.
Configuring a Data Export Policy
By default, all users can download and dump the execution results of SQL scripts. If you do not want all users to have this permission, perform the following steps to configure a data export policy:
  2. Choose Default Configuration and set Data Export Policy.
    The default data export policy is All User Can.
    • All User Can: All users can download and dump SQL execution results.
    • All User Cannot: No user can download or dump SQL execution results.
    • Only Workspace Manager Can: Only workspace administrators can download and dump SQL execution results.
  3. Click Save.
Disabling Auto Node Name Change
On the Develop Job page, when you select a script for a node or associate a node with the function of another cloud service, the node name will be automatically changed to the script name or function name. You can disable this function.
  2. Choose Default Configuration. Find Disable Auto Node Name Change and select job nodes.
    • You can disable automatic name change for the following nodes: CDM Job, DIS Stream, DLI SQL, DWS SQL, MRS Spark SQL, MRS Hive SQL, MRS Presto SQL, MRS HetuEngine, MRS ClickHouse, MRS Impala SQL, Shell, RDS SQL, Subjob, For Each, Doris SQL, or Python.
    • No job nodes are selected by default.
    • Names of the selected nodes will not be automatically changed when a script is selected or a function is associated with them.
  3. Click Save.
Default type and mode of a new job.
Example: a batch processing pipeline job
After setting the default values, click Save.
The simple variable set provides a series of customized variables to dynamically replace parameters during task scheduling.
  1. In the navigation pane on the Data Development page, choose Configuration > Configure.
  2. Choose Default Configuration and set Use Simple Variable Set.
    • Yes: Simple variable sets are supported. A series of customized variables provided by the simple variable set. Customized parameters are automatically replaced with specific values based on the service date, plan time, and parameter value format of task scheduling. In this way, parameters can be dynamically replaced during task scheduling.
    • No: Simple variable sets are not supported.
To configure the notification type for jobs whose status is failure ignored, perform the following steps:
  2. Choose Default Configuration and set Notification Policy for Jobs in Failure Ignored Status.
  3. Select a notification type for jobs whose status is failure ignored.
    • Jobs whose status is failure ignored are those whose Policy for Handling Subsequent Nodes If the Current Node Fails is set to Go to the next node. By default, such jobs are deemed successful by the system.
    • You can configure either of the following notification types for such jobs:
      Abnormal
      Successful (default)
  4. Click Save.
Setting Retry Node upon Timeout
You can set this parameter to specify whether a node will be re-executed if it fails upon timeout.
  3. Set Retry Node upon Timeout.
    • No: A node will not be re-executed if it fails upon timeout.
    • Yes: A node will be re-executed if it fails upon timeout.
  4. Click Save to save the settings.
You can specify whether to exclude waiting time from instance timeout duration.
  2. Choose Default Configuration and set Exclude Waiting Time from Instance Timeout Duration.
  3. Select Yes or No.
    Yes: The waiting time before an instance starts running is excluded from the instance timeout duration.
    No: The waiting time before an instance starts running is included in the instance timeout duration.
You can set the rule for splitting the string parameters (enclosed by "") in the JAR package parameters of MRS MapReduce and MRS Spark operators.
  2. Choose Default Configuration and set Rules for Splitting MRS JAR Package Parameters.
  3. Select a rule.
    Split String Arguments by Space: For example, "select * from table" is split into four parameters by space: select, *, from, and table.
    Do not split string arguments: For example, "select * from table" is regarded as one parameter and is not split. If this parameter is set to Do not split string arguments, data in JSON format can be transferred to JAR package parameters.
You can specify whether a waiting instance can synchronize the latest job version.
  2. Choose Default Configuration and set Synchronization of Job Version by Waiting Instance.
    Yes: The waiting instance uses the latest job version.
    No: The waiting instance still uses the existing job version.
When Hive SQL and Spark SQL statements are executed, DataArts Studio can place SQL statements in OBS or in the request body.
  3. Set Execution Mode for Hive SQL and Spark SQL Statements.
    In OBS: Hive SQL and Spark SQL statements are put in OBS, and the OBS is returned to MRS.
    In the request message body: Hive SQL and Spark SQL statements are put in the request message body, and the script content is returned to MRS.
    This configuration supports Hive SQL and Spark SQL scripts, and pipeline and single-task jobs.
Setting PatchData Priority
You can set the priority of a PatchData job. When system resources are insufficient, computing resources are preferentially allocated to jobs with higher priorities. A larger number indicates a higher priority. Currently, only the priorities of DLI SQL operators can be set.
  2. Choose Default Configuration and set PatchData Job Priority.
  3. Set the patch data priority policy.
    The mapping between the PatchData Job Priority and spark.sql.dli.job.priority of DLI is as follows:
    If PatchData Job Priority is set to 1, spark.sql.dli.job.priority of DLI is 1.
    If PatchData Job Priority is set to 2, spark.sql.dli.job.priority of DLI is 3.
    If PatchData Job Priority is set to 3, spark.sql.dli.job.priority of DLI is 5.
    If PatchData Job Priority is set to 4, spark.sql.dli.job.priority of DLI is 8.
    If PatchData Job Priority is set to 5, spark.sql.dli.job.priority of DLI is 10.
You can set the number of retention days for waiting job instances. If the waiting time of a job instance exceeds the configured retention days, the job instance is canceled. The minimum number of retention days is 1, that is, a job instance which is not executed can be canceled after at least one day. The default number of retention days is 60.
  3. Set the number of retention days for waiting job instances.
Send Alarm Upon Instance Cancellation If you select Yes for this parameter and configure a cancellation notification for a job, an alarm notification will be sent when a historical job instance is canceled upon timeout. If you select No, no alarm notification will be sent.
  3. Set Send Alarm Upon Instance Cancellation.
You can set the number of days during which alarms can be generated for monitored job instances. The default value is seven days. Alarms cannot be sent for job instances beyond the seven-day period.
For example, if you set the value of this parameter to 2, alarms can be generated for the job instances of yesterday and today, but cannot be generated for the job instances of the day before yesterday and of an earlier time even if the triggering conditions are met.
  2. Choose Default Configuration and locate Historical Job Instance Alarm Policy.
  3. Set the number of days during which alarms can be generated for monitored job instances.
    The default value is 7. Set a value from 1 to 270.
    After you set this parameter, alarms are generated only for the job instances which are created after this parameter is set and not for historical instances.
You can set the topic used to send notifications by owner.
  3. Set Job Alarm Notification Topic. Click View Topic to go to the SMN console to view available topics.
    You can only select a topic that you created on the SMN console (to prevent conflict with any existing topic). Only the workspace administrator can configure topic.
This policy takes effect only for new job operators in the current workspace. The default policy for the operators in historical jobs is not affected. The default value is No.
  3. Set Default Retry Policy upon Job Operator Failure.
    If this parameter is set to Yes, new job operators can be retried once, and the retry interval is 120 seconds by default.
If you enable this function, an alarm is generated each time a job fails to be retried.
  3. Set Generate Alarm Upon Job Retry Failure.
    • If you select All jobs, Real-time jobs, or Batch jobs, an alarm is generated each time a job fails to be retried.
    • If you select Disable, an alarm is generated only when the maximum number of retries has been reached for the job.
If this function is enabled, set mapreduce.job.name="Script name" of the Hive SQL script is automatically transferred to MRS during job execution in the current workspace.
This function takes effect only if the preceding parameter value has not been set for the script. If the parameter value has been set for the script, the value set is preferentially read and transferred to MRS. This function is unavailable for MRS clusters in security mode. To enable this function for such clusters, set them to non-security mode.
  3. Set Automatic Script Name Transfer During Job Execution.
    • Yes: The system automatically transfers the Hive SQL script name to MRS during job execution.
    • No: The system does not automatically transfer the Hive SQL script name to MRS during job execution.
Job Dependency Rule
  3. Configure Job Dependency Rule.
    • Jobs cannot be depended on by jobs in other workspaces: Jobs in this workspace cannot be depended on by jobs in other workspaces.
    • Jobs can be depended on by jobs in other workspaces: Jobs in this workspace can be depended on by jobs in other workspaces, without requiring the permissions of this workspace.
    • Jobs can be depended on by jobs in other workspaces (requires the permission to query the job list in the workspace): Jobs in this workspace can be depended on by jobs in other workspaces, requiring the permissions of this workspace. If you do not have the permissions, the system displays a message indicating that you do not have the permission to obtain the job list in workspace xxx when you configure job dependencies across workspaces.
If a job has a downstream dependency, you can configure whether to allow the job to stop scheduling.
  3. Whether to allow a job to stop scheduling when the job has a downstream dependency.
    Yes: If a job has a downstream dependency, a message is displayed when you stop the scheduling of the job, but you can continue to stop the scheduling.
    No: If a job has downstream dependencies, the job scheduling cannot be stopped.
You can set this parameter to control the permissions to view the script execution history.
  3. Set Script Execution History.
After configuring this parameter, you can specify the identity used to test jobs.
  3. Set Identity for Job Tests.
      If no workspace agency or IAM account is available, a personal account is used for job tests.
      If you are using a federated account, you must set this parameter to Public agency or IAM account.
You can set this parameter to determine whether any parameters can be set to overwrite the default parameters of the template.
In the MRS API connection mode, default parameters can be configured for Spark SQL scripts. For proxy connections, this function is not supported.
  3. Set SparkSqlJob/Script Default Template Configuration.
    • Yes: You can set any parameters for jobs and scripts.
    • No: You must select a template for jobs and scripts. The parameters in the template cannot be overwritten during job and script configuration. If you select No, select a default parameter template that has been configured. For details about how to configure a template, see Configuring a Template.
      Then go to the basic information page of the Spark SQL job or Spark SQL script page and click in the upper right corner to view the configured default program parameters. The preset default parameters are unavailable and cannot be modified.
      You can also customize program parameters, which can replace the template parameters during the execution of Spark SQL jobs or scripts.
You can set this parameter to determine whether parameters can be set to overwrite the default parameters of the template.
In the MRS API connection mode, default parameters can be configured for Hive SQL scripts. For proxy connections, this function is not supported.
  3. Set HiveSqlJob/Script Default Template Configuration.
      Then go to the basic information page of the Hive SQL job or Hive SQL script page and click in the upper right corner to view the configured default program parameters. The preset default parameters are unavailable and cannot be modified.
      You can also customize program parameters, which can replace the template parameters during the execution of Hive SQL jobs or scripts.
If you enable this function, you can export job/script changes (addition, modification, and deletion) in a workspace to a .zip file, and import the file to another workspace.
  2. Click Default Configuration.
  3. Set Job/Script Change Management.
    You can export and import jobs and scripts in the workspace only if you have set Job/Script Change Management to Yes.
Log Open Mode
You can configure whether to open logs on a new tab or in a pop-up window.
  2. Choose Default Configuration and locate Log Open Mode.
  3. Select New tab or Pop-up.
    • New tab: Logs are opened on a new page.
    • Pop-up: Logs are opened in a pop-up window on the current page.
You can use this configuration item to determine whether tags can be created for jobs.
  2. Choose Default Configuration and set If No Tag Is Available.
  3. You can select Strict mode or Create one.
    Strict mode: You can enter a tag or select an existing tag. If no tag is available, a tag is automatically created.
    Create one: You can only select an existing tag. If a new tag is detected when you submit a job, an error message is displayed indicating that the tag was not found and must be added on the Tags page.
  4. Click Save.
