MRS ClickHouse Link Parameters
Table 1 describes the MRS ClickHouse link parameters.
- The Elasticsearch connector only supports Elasticsearch clusters in non-security mode.
- Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
| Parameter | Description | Example Value |
| Name | Link name | cklink |
| Database Server | IP address or domain name of the database to connect NOTE: DataArts Studio does not support MRS clusters whose Kerberos encryption type is aes256-sha2,aes128-sha2, and only supports MRS clusters whose Kerberos encryption type is aes256-sha1,aes128-sha1. Log in to Manager of the cluster where the MRS ClickHouse data source is located, choose Cluster > Services > ClickHouse > Instance, and view the ClickHouseServer service IP address. | 192.168.0.1 |
| Port | Port of the database to connect NOTE:
| 8123 |
| Database Name | Name of the database to connect | dbname |
| Username | Username used for accessing the database. This user must have the permissions to read and write data tables and metadata. | cdm |
| Password | Password of the user | - |
| SSL Encryption | (Optional) If you set this parameter to Yes, CDM can connect to the database (on-premises databases excluded) in SSL encryption mode. | No |
| Reference Sign | (Optional) Delimiter between the names of the referenced tables or columns. For details, see the product documentation of the corresponding database. | ' |
| Custom connection attributes | This parameter is optional. You can click Add to add attributes of specified data sources. The following are some examples: socketTimeout=300000 (unit: ms) | - |
| Fetch Size | Number of rows obtained by each request | 50000 |
