HDFS Link Parameters
- MRS HDFS
- FusionInsight HDFS
- Apache HDFS
Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
MRS HDFS
When connecting CDM to HDFS of MRS, configure the parameters as described in Table 1.
MRS clusters whose Kerberos encryption type is aes256-sha2,aes128-sha2 are not supported, and only MRS clusters whose Kerberos encryption type is aes256-sha1,aes128-sha1 are supported.
- Before creating an MRS link, you need to add an authenticated Kerberos user on MRS and log in to the MRS management page to change the initial password. Then use the new user to create an MRS link.
- To connect to an MRS 2.x cluster, create a CDM cluster of version 2.x first. CDM 1.8.x clusters cannot connect to MRS 2.x clusters.
- If the connection fails after you select a cluster, check whether the MRS cluster can communicate with the CDM instance which functions as the agent. They can communicate with each other in the following scenarios:
- If the CDM cluster in the DataArts Studio instance and the MRS cluster are in different regions, a public network or a dedicated connection is required. If the Internet is used for communication, ensure that an EIP has been bound to the CDM cluster, and the MRS cluster can access the Internet and the port has been enabled in the firewall rule.
- If the CDM cluster in the DataArts Studio instance and the MRS cluster are in the same region, VPC, subnet, and security group, they can communicate with each other by default. If they are in the same VPC but in different subnets or security groups, you must configure routing rules and security group rules. For details about how to configure routing rules, see Configuring Routing Rules. For details about how to configure security group rules, see Configuring Security Group Rules.
- The MRS cluster and the DataArts Studio workspace belong to the same enterprise project. If they do not, you can modify the enterprise project of the workspace.
If an agent is connected to multiple MRS clusters and one of the MRS clusters is deleted or abnormal, connections to the other MRS clusters will be affected. Therefore, you are advised to connect an agent to only one MRS cluster.
| Parameter | Description | Example Value |
| Name | Link name, which should be defined based on the data source type, so it is easier to remember what the link is for | mrs_hdfs_link |
| Manager IP | Enter or select the Manager IP address. You can click Select to select a created MRS cluster. CDM automatically fills in the authentication information. If the Hadoop type is MRS, enter the IP address of MRS Manager. If the Hadoop type is FusionInsight HD, enter the IP address of FusionInsight HD Manager. Enter the IP address based on the scenario and sequence.
NOTE: MRS clusters whose Kerberos encryption type is aes256-sha2,aes128-sha2 are not supported, and only MRS clusters whose Kerberos encryption type is aes256-sha1,aes128-sha1 are supported. |
| Username | If Authentication Method is set to KERBEROS, you must provide the username and password used for logging in to MRS Manager. If you need to create a snapshot when exporting a directory from HDFS, the user configured here must have the administrator permission on HDFS. To create a data connection for an MRS security cluster, do not use user admin. The admin user is the default management page user and cannot be used as the authentication user of the security cluster. You can create an MRS user and set Username and Password to the username and password of the created MRS user when creating an MRS data connection. NOTE:
| cdm |
| Password | Password used for logging in to MRS Manager | - |
| Authentication Method | Authentication method used for accessing MRS
| SIMPLE |
| Run Mode | Run mode of the HDFS link. The options are as follows:
If a CDM cluster connects to two or more clusters with Kerberos authentication enabled and the same realm, only one cluster can be connected in EMBEDDED mode, and the other clusters must be connected in STANDALONE mode. | STANDALONE |
| Agent | The agent function will be unavailable soon and does not need to be configured. | - |
| Use Cluster Config | You can use the cluster configuration to simplify parameter settings for the Hadoop connection. | No |
| Cluster Config Name | This parameter is valid only when Use Cluster Config is set to Yes. Select a cluster configuration that has been created. For details about how to configure a cluster, see Managing Cluster Configurations. | hdfs_01 |
Click Show Advanced Attributes, and then click Add to add configuration attributes of other clients. The name and value of each attribute must be configured. You can click Delete to delete no longer used attributes.
FusionInsight HDFS
When connecting CDM to HDFS of FusionInsight HD, configure the parameters as described in Table 2.
| Name | Link name, which should be defined based on the data source type, so it is easier to remember what the link is for | FI_hdfs_link |
| Manager IP | IP address of FusionInsight Manager | 127.0.0.1 |
| Manager Port | Port number of FusionInsight Manager | 28443 |
| CAS Server Port | Port number of the CAS server used to connect to FusionInsight | 20009 |
| Username | Username used for logging in to FusionInsight Manager. If you need to create a snapshot when exporting a directory from HDFS, the user configured here must have the administrator permission on HDFS. | cdm |
| Password | Password used for logging in to FusionInsight Manager | - |
| Authentication Method | Authentication method used for accessing the cluster:
| KERBEROS |
| STANDALONE |
Apache HDFS
When connecting CDM to HDFS of Apache Hadoop, configure the parameters as described in Table 3.
| Name | Link name, which should be defined based on the data source type, so it is easier to remember what the link is for | hadoop_hdfs_link |
| URI | NameNode URI You can enter hdfs://IP address of the NameNode instance:8020. | hdfs://IP:8020 |
| KERBEROS |
| STANDALONE |
| IP and Host Name Mapping | This parameter is used only when Run Mode is set to EMBEDDED or STANDALONE. If the HDFS configuration file uses the host name, configure the mapping between the IP address and host name. Separate the IP addresses and host names by spaces and mappings by semicolons (;), carriage returns, or line feeds. | 10.1.6.9 hostname01 10.2.7.9 hostname02 |
| Cluster Config Name | This parameter is valid when Use Cluster Config is set to Yes or Authentication Method is set to KERBEROS. Select a cluster configuration that has been created. For details about how to configure a cluster, see Managing Cluster Configurations. | hdfs_01 |
