DLI Link Parameters
When connecting CDM to DLI, configure the parameters as described in Table 1.
Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
- When data is migrated to DLI, DLI generates data files in the dli-trans* temporary OBS bucket. Therefore, you need to grant the user who uses the AK/SK the permissions to read and write the dli-trans* bucket and create directories. Otherwise, the migration will fail. For details about how to add permission policies for temporary bucket dli-trans*, see Adding an Authorization Policy for the dli-trans* Temporary Bucket.
| Parameter | Description | Example Value |
| Name | Link name, which should be defined based on the data source type, so it is easier to remember what the link is for | dli_link |
| AK | AK/SK required for authentication during access to the DLI database. You need to create an access key for the current account and obtain an AK/SK pair.
| SK | - | |
| Project ID | Project ID in the region where DLI resides A project is a group of tenant resources, and an account ID corresponds to the current account. The IAM ID corresponds to the current user. You can view the project IDs, account IDs, and user IDs in different regions on the corresponding pages.
| Batch Size | Number of rows written each time. When the number of rows written reaches the value of Commit Size, the rows will be committed to the database. | 50000 |
| Link Attributes | This parameter is optional. You can click Add to add attributes for the link to multiple specified data sources. jobTimeout: DLI link timeout interval, in seconds | - |
- Log in to the IAM console.
- In the navigation pane, choose Permissions > Policies/Roles and click Create Custom Policy in the upper right corner. Figure 2 Creating a custom policy
- On the Create Custom Policy page, select JSON for Policy View and create custom policy obs_dli-trans.
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "obs:object:GetObject", "obs:object:DeleteObjectVersion", "obs:bucket:GetBucketLocation", "obs:object:GetAccessLabel", "obs:bucket:PutEncryptionConfiguration", "obs:bucket:PutBucketStoragePolicy", "obs:object:DeleteAccessLabel", "obs:bucket:PutBucketCustomDomainConfiguration", "obs:bucket:GetLifecycleConfiguration", "obs:bucket:PutBucketInventoryConfiguration", "obs:bucket:DeleteDirectColdAccessConfiguration", "obs:object:AbortMultipartUpload", "obs:bucket:PutBucketLogging", "obs:bucket:DeleteBucketWebsite", "obs:object:DeleteObject", "obs:bucket:PutBucketVersioning", "obs:bucket:GetBucketWebsite", "obs:bucket:GetBucketLogging", "obs:bucket:DeleteBucketCustomDomainConfiguration", "obs:object:PutObject", "obs:object:RestoreObject", "obs:bucket:PutReplicationConfiguration", "obs:bucket:GetBucketQuota", "obs:object:GetObjectVersionAcl", "obs:bucket:DeleteBucket", "obs:bucket:CreateBucket", "obs:bucket:GetDirectColdAccessConfiguration", "obs:bucket:PutDirectColdAccessConfiguration", "obs:bucket:GetBucketAcl", "obs:bucket:GetBucketVersioning", "obs:bucket:GetBucketInventoryConfiguration", "obs:bucket:GetBucketStoragePolicy", "obs:bucket:GetEncryptionConfiguration", "obs:bucket:PutBucketCORS", "obs:bucket:PutBucketTagging", "obs:bucket:GetBucketTagging", "obs:bucket:PutLifecycleConfiguration", "obs:bucket:GetBucketCustomDomainConfiguration", "obs:object:ListMultipartUploadParts", "obs:object:ModifyObjectMetaData", "obs:bucket:ListBucketVersions", "obs:bucket:PutBucketQuota", "obs:object:PutAccessLabel", "obs:bucket:ListBucket", "obs:bucket:GetBucketCORS", "obs:bucket:DeleteBucketInventoryConfiguration", "obs:object:GetObjectVersion", "obs:bucket:PutBucketWebsite", "obs:bucket:DeleteReplicationConfiguration", "obs:object:GetObjectAcl", "obs:bucket:GetBucketNotification", "obs:bucket:PutBucketNotification", "obs:bucket:GetReplicationConfiguration", "obs:bucket:GetBucketPolicy", "obs:bucket:DeleteBucketTagging", "obs:bucket:GetBucketStorage" ], "Resource": [ "OBS:*:*:object:*", "OBS:*:*:bucket:dli-trans*" ] } ] }Figure 3 Creating custom policy obs_dli-trans
- Click OK.
- In the navigation pane, choose User Groups, locate the user group to which the DLI link user using the AK/SK belongs, and click Authorize to assign the custom obs_dli-trans policy to the user. Figure 4 Assigning the custom obs_dli-trans policy to a user group
