DIS Link Parameters
When connecting CDM to DIS, configure the parameters as described in Table 1.
Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
Parameter |
Description |
Example Value |
Name |
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for |
dis_link |
Region |
Region where DIS is deployed |
Endpoint |
URL of DIS in the format of https://Endpoint. An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. You can obtain the endpoints of the service from Regions and Endpoints. |
AK |
AK used for logging in to the DIS server. You need to create an access key for the current account and obtain an AK/SK pair. |
SK |
SK used for logging in to the DIS server. You need to create an access key for the current account and obtain an AK/SK pair. |
Project ID |
Project ID of DIS |
