Updated on 2026-08-21 GMT+08:00
Kafka Link Parameters
MRS Kafka
When connecting CDM to Kafka of MRS, configure the parameters as described in Table 1.
  • Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
Table 1 MRS Kafka link parameters
Example Value
Name
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for
kafka_link
Manager IP
Enter or select the Manager IP address.
You can click Select to select a created MRS cluster. CDM automatically fills in the authentication information.
If the Hadoop type is MRS, enter the IP address of MRS Manager.
If the Hadoop type is FusionInsight HD, enter the IP address of FusionInsight HD Manager.
Enter the IP address based on the scenario and sequence.
  • If you enter one IP address, enter the management-plane floating IP address of the MRS cluster.
  • If you enter two IP addresses, enter the IP addresses of the active and standby nodes on the service plane of the MRS cluster. Use semicolons (;) to separate the IP addresses.
  • If you enter three IP addresses, enter the IP address of the active node on the service plane of the MRS cluster, IP address of the standby node on the service plane of the MRS cluster, and the floating IP address of the management plane of the MRS cluster. Use semicolons (;) to separate the IP addresses.
MRS clusters whose Kerberos encryption type is aes256-sha2,aes128-sha2 are not supported, and only MRS clusters whose Kerberos encryption type is aes256-sha1,aes128-sha1 are supported.
  • 127.0.0.1
  • 127.0.0.1;127.0.0.2;127.0.0.3
Username
Username used for logging in to MRS Manager
To create a data connection for an MRS security cluster, do not use user admin. The admin user is the default management page user and cannot be used as the authentication user of the security cluster. You can create an MRS user and set Username and Password to the username and password of the created MRS user when creating an MRS data connection.
  • If the CDM cluster version is 2.9.0 or later and the MRS cluster version is 3.1.0 or later, the created user must have the permissions of the Manager_viewer role to create links on CDM. To perform operations on databases, tables, and columns of an MRS component, you also need to add the database, table, and column permissions of the MRS component to the user by following the instructions in the MRS documentation.
  • If the CDM cluster version is earlier than 2.9.0 or the MRS cluster version is earlier than 3.1.0, the created user must have the permissions of Manager_administrator or System_administrator to create links on CDM.
  • A user with only the Manager_tenant or Manager_auditor permission cannot create connections.
Password
Password used for logging in to MRS Manager
Authentication Method
Authentication method used for accessing MRS
  • SIMPLE: for non-security mode
  • KERBEROS: for security mode
Yes
Click Show Advanced Attributes, and then click Add to add configuration attributes of other clients. The name and value of each attribute must be configured. You can click Delete to delete no longer used attributes.
Apache Kafka
The Apache Kafka link is applicable to data migration of the third-party Hadoop in the local data center or ECS. You must use Direct Connect to connect to Hadoop in the local data center.
When connecting CDM to Kafka of Apache Hadoop, configure the parameters as described in Table 2.
Table 2 Parameter description
Example Value
Name
kafka_link
Kafka broker
IP address and port number of the Kafka broker
192.168.1.1:9092
