MongoDB Link Parameters
This link is used to transfer data from a third-party cloud MongoDB service or MongoDB created in the on-premises data center or ECS to a big data platform.
When connecting CDM to an on-premises MongoDB database, configure the parameters as described in Table 1.
- MongoDB data sources with SSL enabled are not supported.
- Do not change the password or user when a job is running. If you do so, the password will not take effect immediately and the job will fail.
Parameter |
Description |
Example Value |
Name |
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for |
mongodb_link |
Server List |
List of MongoDB server addresses. Enter each address in the format of IP address or domain name of the database server:port number, and separate the entered addresses with semicolons (;). |
192.168.0.1:7300;192.168.0.2:7301 |
Database Name |
Name of the MongoDB database to be connected |
DB_mongodb |
Username |
Username for logging in to MongoDB |
cdm |
Password |
Password for logging in to MongoDB |
Direct Connection |
This mode applies to the scenario where the network of the primary node is normal but the network of the replica node is abnormal.
No |
Link Attributes |
Custom link attributes. The MongoDB attributes are supported. The unit is ms. The link attributes are as follows:
socketTimeout=60000 |
