Updated on 2026-03-20 GMT+08:00
Hive Link Parameters
CDM supports the following Hive data sources:
MRS Hive
You can view a table during field mapping only when you have the permission to access the table connected to MRS Hive.
MRS Hive links apply to the MapReduce Service (MRS) on Huawei Cloud. Table 1 describes related parameters.
  • MRS clusters whose Kerberos encryption type is aes256-sha2,aes128-sha2 are not supported, and only MRS clusters whose Kerberos encryption type is aes256-sha1,aes128-sha1 are supported.
  • Before creating an MRS Hive link, you need to add an authenticated Kerberos user on MRS and log in to the MRS management page to change the initial password. Then use the new user to create an MRS link.
  • To connect to an MRS 2.x cluster, create a CDM cluster of version 2.x first. CDM 1.8.x clusters cannot connect to MRS 2.x clusters.
  • Currently, the Hive link obtains the core-site.xml configuration information from MRS HDFS. Therefore, if MRS Hive uses OBS as the underlying storage system, configure the AK/SK of OBS on MRS HDFS before creating the Hive link.
  • Ensure that the MRS cluster and the DataArts Studio instance can communicate with each other. The following requirements must be met for network interconnection:
    • If the CDM cluster in the DataArts Studio instance and the MRS cluster are in different regions, a public network or a dedicated connection is required. If the Internet is used for communication, ensure that an EIP has been bound to the CDM cluster, and the MRS cluster can access the Internet and the port has been enabled in the firewall rule.
    • If the CDM cluster in the DataArts Studio instance and the MRS cluster are in the same region, VPC, subnet, and security group, they can communicate with each other by default. If they are in the same VPC but in different subnets or security groups, you must configure routing rules and security group rules. For details about how to configure routing rules, see Configuring Routing Rules. For details about how to configure security group rules, see Configuring Security Group Rules.
    • The MRS cluster and the DataArts Studio workspace belong to the same enterprise project. If they do not, you can modify the enterprise project of the workspace.
Table 1 MRS Hive link parameters
Example Value
Name
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for
hivelink
Manager IP
Enter or select the Manager IP address.
You can click Select to select a created MRS cluster. CDM automatically fills in the authentication information.
If the Hadoop type is MRS, enter the IP address of MRS Manager.
If the Hadoop type is FusionInsight HD, enter the IP address of FusionInsight HD Manager.
Enter the IP address based on the scenario and sequence.
  • If you enter one IP address, enter the management-plane floating IP address of the MRS cluster.
  • If you enter two IP addresses, enter the IP addresses of the active and standby nodes on the service plane of the MRS cluster. Use semicolons (;) to separate the IP addresses.
  • If you enter three IP addresses, enter the IP address of the active node on the service plane of the MRS cluster, IP address of the standby node on the service plane of the MRS cluster, and the floating IP address of the management plane of the MRS cluster. Use semicolons (;) to separate the IP addresses.
  • 127.0.0.1
  • 127.0.0.1;127.0.0.2;127.0.0.3
Authentication Method
Authentication method used for accessing MRS
  • SIMPLE: Select this for non-security mode.
  • KERBEROS: Select this for security mode.
SIMPLE
Kerberos Authentication Type
This parameter is displayed when Authentication Method is set to KERBEROS.
You can select the BASIC or KEYTAB authentication type.
  • BASIC: The username and password are used for authentication.
    When you select this option:
    • The link can be used as the source link. Data can be read through JDBC but not HDFS at the source, and concurrent reading is not supported.
    • The link cannot be used as the destination link.
    • HIVE_3_X is supported.
  • KEYTAB: The keytab file is used for authentication.
KEYTAB
HIVE Version
Set this to the Hive version on the server.
HIVE_3_X
Username
If Authentication Method is set to KERBEROS, you must provide the username and password used for logging in to MRS Manager. If you need to create a snapshot when exporting a directory from HDFS, the user configured here must have the administrator permission on HDFS.
To create a data connection for an MRS security cluster, do not use user admin. The admin user is the default management page user and cannot be used as the authentication user of the security cluster. You can create an MRS user and set Username and Password to the username and password of the created MRS user when creating an MRS data connection.
  • If the CDM cluster version is 2.9.0 or later and the MRS cluster version is 3.1.0 or later, the created user must have the permissions of the Manager_viewer role to create links on CDM. To perform operations on databases, tables, and columns of an MRS component, you also need to add the database, table, and column permissions of the MRS component to the user by following the instructions in the MRS documentation.
  • If the CDM cluster version is earlier than 2.9.0 or the MRS cluster version is earlier than 3.1.0, the created user must have the permissions of Manager_administrator or System_administrator to create links on CDM.
  • A user with only the Manager_tenant or Manager_auditor permission cannot create connections.
cdm
Password
Password used for logging in to MRS Manager
Enable ldap
This parameter is available when Proxy connection is selected for Connection Type.
If LDAP authentication is enabled for an external LDAP server connected to MRS Hive, the LDAP username and password are required for authenticating the connection to MRS Hive. In this case, this option must be enabled. Otherwise, the connection will fail.
No
ldapUsername
This parameter is mandatory when Enable ldap is enabled.
Enter the username configured when LDAP authentication was enabled for MRS Hive.
ldapPassword
Enter the password configured when LDAP authentication was enabled for MRS Hive.
OBS storage support
The server must support OBS storage. When creating a Hive table, you can store the table in OBS.
No
AK
This parameter is mandatory when OBS storage support is enabled. The account corresponding to the AK/SK pair must have the OBS Buckets Viewer permission. Otherwise, OBS cannot be accessed and the "403 AccessDenied" error is reported.
You need to create an access key for the current account and obtain an AK/SK pair.
  1. Log in to the management console, move the cursor to the username in the upper right corner, and select My Credentials from the drop-down list.
  2. On the My Credentials page, choose Access Keys, and click Create Access Key. See Figure 1.
    Figure 1 Clicking Create Access Key
  3. Click OK and save the access key file as prompted. The access key file will be saved to your browser's configured download location. Open the credentials.csv file to view Access Key Id and Secret Access Key.
    • Only two access keys can be added for each user.
    • To ensure access key security, the access key is automatically downloaded only when it is generated for the first time and cannot be obtained from the management console later. Keep them properly.
SK
Project ID
Project ID
Run Mode
This parameter is used only when the Hive version is HIVE_3_X. Possible values are:
  • EMBEDDED: The link instance runs with CDM. This mode delivers better performance.
  • Standalone: The link instance runs in an independent process. If CDM needs to connect to multiple Hadoop data sources (MRS, Hadoop, or CloudTable) with both Kerberos and Simple authentication modes, Standalone prevails.
    The STANDALONE mode is used to solve the version conflict problem. If the connector versions of the source and destination ends of the same link are different, a JAR file conflict occurs. In this case, you need to place the source or destination end in the STANDALONE process to prevent the migration failure caused by the conflict.
EMBEDDED
Check Hive JDBC Connectivity
Whether to check the Hive JDBC connectivity
No
Use Cluster Config
You can use the cluster configuration to simplify parameter settings for the Hadoop connection.
No
Cluster Config Name
This parameter is valid only when Use Cluster Config is set to Yes. Select a cluster configuration that has been created.
For details about how to configure a cluster, see Managing Cluster Configurations.
hive_01
Click Show Advanced Attributes, and then click Add to add configuration attributes of other clients. The name and value of each attribute must be configured. You can click Delete to delete no longer used attributes.
The following are some examples:
  • connectTimeout=360000 and socketTimeout=360000: When a large amount of data needs to be migrated or the entire table is retrieved using query statements, the migration fails due to connection timeout. In this case, you can customize the connection timeout interval (ms) and socket timeout interval (ms) to prevent failures caused by timeout.
  • hive.server2.idle.operation.timeout=360000: To prevent Hive migration jobs from being suspended for a long time, you can customize the operation timeout period (ms).
  • hive.storeFormat=textfile: During data migration from a relational database to Hive, tables in ORC format are automatically created by default. If you want textfile or parquet tables to be created, add hive.storeFormat=textfile or hive.storeFormat=parquet.
  • fs.defaultFS=obs://hivedb: If the interconnected MRS Hive uses decoupled storage and compute, you can use this configuration to achieve better compatibility.
  • config.hive.server: specifies the connection address and port of the HiveServer. Only one node can be specified. Example: 127.0.0.1:10000.
    If you set config.hive.server:
FusionInsight Hive
The FusionInsight Hive link is applicable to data migration of FusionInsight HD in the local data center. You must use Direct Connect to connect to FusionInsight HD.
Table 2 describes related parameters.
Table 2 FusionInsight Hive link parameters
Example Value
Name
hivelink
Manager IP
IP address of FusionInsight Manager
127.0.0.1
Manager Port
Port number of FusionInsight Manager
28443
CAS Server Port
Port number of the CAS server used to connect to FusionInsight
20009
Authentication method used for accessing the cluster:
SIMPLE
HIVE Version
Hive version
HIVE_3_X
Username
Username used for logging in to FusionInsight Manager.
cdm
Password
Password used for logging in to FusionInsight Manager
OBS storage support
No
AK
  2. On the My Credentials page, choose Access Keys, and click Create Access Key. See Figure 2.
    Figure 2 Clicking Create Access Key
SK
Run Mode
EMBEDDED
Use Cluster Config
No
Cluster Config Name
hive_01
Apache Hive
The Apache Hive link is applicable to data migration of the third-party Hadoop in the local data center or ECS. You must use Direct Connect to connect to Hadoop in the local data center.
Table 3 describes related parameters.
Table 3 Apache Hive link parameters
Example Value
Name
hivelink
URI
NameNode URI
hdfs://hacluster
Hive Metastore
Hive metadata address. For details, see the hive.metastore.uris configuration item. Example: thrift://host-192-168-1-212:9083
SIMPLE
Hive Version
Hive version
HIVE_3_X
IP and Host Name Mapping
If the Hadoop configuration file uses the host name, configure the mapping between the IP address and host name. Separate the IP addresses and host names by spaces and mappings by semicolons (;), carriage returns, or line feeds.
OBS storage support
No
AK
  2. On the My Credentials page, choose Access Keys, and click Create Access Key. See Figure 3.
    Figure 3 Clicking Create Access Key
SK
Run Mode
EMBEDDED
Use Cluster Config
No
Cluster Config Name
This parameter is valid when Use Cluster Config is set to Yes or Authentication Method is set to KERBEROS. Select a cluster configuration that has been created.
hive_01
Hive JDBC URL
URL for connecting to Hive JDBC. By default, anonymous users are used.
