Viewing Repository Details
In the repository list, click a repository name to go to the repository details page. CodeArts Repo provides abundant console operations.
Page |
Function Description |
Displays the repository capacity, commits number , branches number , tags number , members number, LFS usage, creation time, creator, visible scope, repository status, README file, language, and percentage of each language. |
Merge requests of branches can be managed on the console. |
You can view the review records of MRs and commits. |
List of associated work items. You can associate CodeArts Req work items with the repository code to improve efficiency. |
Visualized charts of repository commits, such as code contribution. |
You can view the dynamic information about the repository. |
You can manage repository members, for example, synchronizing members from the project by one click or changing the permissions of a member. |
Repository settings. Only the repository administrator and the repository creator can view this tab page and configure settings. |
In addition, the repository details page provides quick entries to the following functions:
- Configure builds: Create a build task.
- Follow: Click to follow the repository. The followed repositories are pinned on top.
- Fork: displays the number of forks of a repository. You can click this button to create a fork.
- Clone/Download: You can obtain the SSH address and HTTPS address of a repository or directly download the code package.
The following figures show the adaptation function of CodeArts Repo. When the length of the repository page is greater than the window length, the repository tab page is moved to the top after you scroll down. The position in the red box in the following figure is collapsed so you can view repository information easily. After you scroll up, the page layout is restored.
