Configuring Roles and Permissions
CodeArts Build allows you to configure permissions for each role of the build task.
- On the page for editing the build task, click the Permissions tab page and configure operation permissions for different roles. For details about the default permissions of each role, see Table 1.
Changes to task creator's permissions are locked down to the project creator themselves and the project manager.
Table 1 Default roles and permissions matrix for CodeArts Build Role
Create
Edit
Delete
View
Execute
Clone
Disable
Assign Permissions
Group
Task creator
Project creator
Project manager
Product manager
Test manager
Operation manager
System engineer
Committer
Developer
Tester
Participant
Viewer
Project admin
- Toggle on Use Project Permissions to synchronize the current build task's permissions with the project's permissions. For details about how to configure project permissions, see Configuring Role Permissions.
Figure 1 Configuring roles and permissions for a build task
