Updated on 2025-10-13 GMT+08:00
Building with Android
The Android build system compiles application resources and source code, and then packages them into APKs that can be deployed, signed, and distributed.
Build on GUI
  1. Add Build with Android, when configuring build actions. Set the parameters according to Table 1.
    Table 1 Parameters for building with Android
    Action Name
    Assign a custom name to the build action. The name can contain:
    • Letters, digits, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), and parentheses.
    • 1 to 128 characters.
    Gradle
    Select a tool version that matches your current development environment.
    For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment.
    JDK
    NDK
    Commands
    Configure the Gradle commands, or use the default ones. For more commands, see the Gradle official website.
    Continue After Failure
    Specify whether to proceed after the current action fails by setting the parameter to either Yes or No.
  2. If you need to use apksigner to sign Android APKs, add the Sign Android APK action and configure the parameters according to the following table.
    Action Name
    APK Location
    Location of the .apk file to be signed after the Android build.
    You can use regular expressions, such as build/bin/*.apk, to match the built APK package.
    Keystore File
    Select the keystore file used for signature from the drop-down list. For details about how to create and upload the file, see Generating the Keystore Signature File and Uploading It for Management.
    Keystore Password
    Optional.
    Enter the custom password of the keystore file.
    Alias
    Assign a custom alias to the key.
    • The value must start with a letter and can contain letters, digits, underscores (_), hyphens (-), and periods (.).
    • The value contains 1 to 128 characters.
    Key Password
    Optional.
    Enter a custom key password.
    apksigner CLI
    Enter a custom signature parameter. By default, --verbose is added to display the signature details.
    Once you have finished configuration, run the build task. If the task is executed successfully, check the build logs. If the logs of the Sign Android APK action display Signed, it means that the signing process was successful.
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
  1. The following sample code is for the Android build:
     3
     4
     5
     6
     7
     8
     9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    version: 2.0 # The value must be 2.0.
    steps:
      BUILD:
        - android:
            inputs:
              gradle: 4.8
              jdk: 1.8
              ndk: 17
              command: |
                cat ~/.gradle/init.gradle
                cat ~/.gradle/gradle.properties
                cat ~/.gradle/init_template.gradle
                rm -rf ~/.gradle/init.gradle
                rm -rf /home/build/.gradle/init.gradle
                # Gradle Wrapper provided by CodeArts Build is used for cache acceleration.
                cp /cache/android/wrapper/gradle-wrapper.jar ./gradle/wrapper/gradle-wrapper.jar
                # Build an unsigned APK.
                /bin/bash ./gradlew assembleDebug -Dorg.gradle.daemon=false -d --stacktrace
             ignore_fail: true
    Table 2 Parameters in the sample code for the Android build
    Type
    command
    String
    Enter the Gradle command. For more commands, see the Gradle official website.
    gradle
    String
    jdk
    String
    ndk
    String
    ignore_fail
    String
    Whether to proceed after the current action fails.
    • true: Yes
    • Empty: No
  2. The following sample code is to sign the Android APK.
     3
     4
     5
     6
     7
     8
     9
    10
    11
    12
    steps:
      BUILD:
        - android_sign:
                inputs:
                   file_path: build/bin/*.apk
                       keystore_file: androidapk.jks
                       keystore_password: xxxxxx
                       alias: keyalias
                       key_password: xxxxxx
                       apksigner_commond: --verbose
                       ignore_fail: true
    Table 3 Parameters in the sample code for signing the Android APK
    Type
    file_path
    String
    keystore_file
    String
    Name of the keystore file. For details about how to create and upload the file, see Generating the Keystore Signature File and Uploading It for Management.
    keystore_password
    String
    Optional.
    alias
    String
    Alias of the keystore file.
    key_password
    String
    Optional.
    apksigner_commond
    String
    ignore_fail
    String
    • true: Yes
    • Empty: No
Android Version Description
  • SDK: used to specify compileSdkVersion.
  • Build Tools: used to specify buildToolsVersion.
You can find the two versions in the build.gradle file or the global configuration file (user-defined) of the project.
  • Select compileSdkVersion or buildToolsVersion based on project requirements.
  • The Gradle wrapper build mode is also supported. If the provided Gradle version does not meet your requirements, you can run the gradlew command for build using the wrapper. The required Gradle version will be automatically downloaded. Example of the build command: ./gradlew clean build.
  1. The keystore signature file can be generated in either of the following ways:
    • Using Keytool in JDK to Generate Signature Files
      1. Find the JDK installation path and run keytool.exe.
      2. Run the following command to generate a .jks file:
        keytool -genkeypair -storepass 123456 -alias apksign -keypass 123456 -keyalg RSA -validity 20000 -keystore D:/android.jks
    • Using Android Studio to Generate Signature Files
      1. Open the Studio client and choose Build > Generate Signed Bundle/APK.
      2. Select APK and click Next.
      3. Click Create new.... In the displayed dialog box, enter related information, and click OK. Then click Next.
      4. View the generated signature file.
  2. You can upload the keystore signature file to the Files page in either of the following ways:
    • In the Build with Android action, click Upload next to Keystore File. In the displayed dialog box, select a file, add a description, select the related agreements, and click Save.
    • On the CodeArts Build homepage, choose More > Files. On the displayed page, click Upload File. In the displayed dialog box, select a file, add a description, select the related agreements, and click Save.
Helpful Links
Hit snags in Android builds? See Android Build FAQs.
