On this page
Building with Bazel
Updated on 2024-11-21 GMT+08:00
Use Bazel to compile and build.
Build on GUI
Add Build with Bazel, when configuring build actions. Set the parameters according to Table 1.
Table 1 Parameters for building with Bazel
Action Name
Assign a custom name to the build action. The name can contain:
  • Letters, digits, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), and parentheses.
  • 1 to 128 characters.
Tool Version
Select a tool version that matches your current development environment.
For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment.
Commands
Configure the Bazel commands, or use the default ones. If you have special build requirements, enter your custom build script in the text box.
Continue After Failure
Specify whether to proceed after the current action fails by setting the parameter to either Yes or No.
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
 3
 4
 5
 6
 7
 8
 9
10
11
version: 2.0 # The value must be 2.0.
steps:
  BUILD:
    - bazel:
        inputs:
          command: |
              cd java-maven
              bazel build //:java-maven_deploy.jar
              mkdir build_out
              cp -r  bazel-bin/*  build_out/
          ignore_fail: true
Table 2 Parameters in the sample code
Type
command
String
Configure the Bazel commands.
ignore_fail
String
Whether to proceed after the current action fails.
  • true: Yes
  • Empty: No
