On this page
Running Shell Commands
Updated on 2025-01-03 GMT+08:00
You can use the action Run Shell Commands to create and run a build task. You can also use this action in conjunction with other build tools. For instance, in a Maven build, you can add the Run Shell Commands action to generate the necessary files for the subsequent build process.
Build on GUI
Add Run Shell Commands, when configuring build actions. Set the parameters according to Table 1.
Table 1 Parameters for running shell commands
Action Name
Assign a custom name to the build action. The name can contain:
  • Letters, digits, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), and parentheses.
  • 1 to 128 characters.
Tool Version
Select a tool version that matches your current development environment.
For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment.
Commands
Enter the shell commands for your build.
Continue After Failure
Specify whether to proceed after the current action fails by setting the parameter to either Yes or No.
Build with Code
Modify the code in the PRE_BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
3
4
5
6
7
version: 2.0 # The value must be 2.0.
steps:
  PRE_BUILD:
    - sh:
        inputs:
          command: echo ${a}
          ignore_fail: true
Table 2 Parameters in the sample code
Type
command
String
ignore_fail
string
Whether to proceed after the current action fails.
  • true: Yes
  • Empty: No
