Building with CMake
Build a cross-platform project with CMake.
Build on GUI
Add Build with CMake, when configuring build actions. Set the parameters according to Table 1.
| Parameter | Description |
| Action Name | Assign a custom name to the build action. The name can contain:
| Tool Version | Select a tool version that matches your current development environment. For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment. |
| Commands | Configure the CMake commands, or use the default ones. If you have special build requirements, enter your custom build script in the text box. For more commands, see the CMake official website. |
| Continue After Failure | Specify whether to proceed after the current action fails by setting the parameter to either Yes or No. |
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
1 2 3 4 5 6 7 8 9 10 11 | version: 2.0 # The value must be 2.0. steps: BUILD: - cmake: inputs: command: | # Create the build directory and switch to the build directory. mkdir build && cd build # Generate makefiles for the Unix platform and perform the build. cmake -G 'Unix Makefiles' ../ && make -j ignore_fail: true |
| Parameter | Type | Description |
| command | String | Configure the CMake commands. For more commands, see the CMake official website. |
| ignore_fail | String | Whether to proceed after the current action fails.
