- What's New
- Function Overview
Getting Started
- Building with Ant and Uploading the Package to a Release Repo (x86, Preset Image, GUI)
- Building with CMake and Uploading the Package to a Release Repo (Arm, Preset Image, GUI)
- Building with Maven, Uploading the Software Package, and Pushing the Image (x86, Preset Image, Code)
- Common Practices for Beginners
User Guide
- Working with CodeArts Build
- Enabling CodeArts Build
- Configuring Project-Level Role Permissions
- Creating a Build Task
Configuring a Build Task
- Performing Basic Configurations
- Selecting Build Actions
Configuring Build Actions
- Building with Android
- Building with npm
- Building with Gradle
- Building with Yarn
- Building with Gulp
- Building with Grunt
- Building with Mono
- Building in PHP
- Building with Setuptools
- Building with PyInstaller
- Running Shell Commands
- Building with GNU Arm
- Building with Ant
- Building with Kotlin
- Building with Go
- Building Android App with Ionic
- Building an Android Quick App
- Building with sbt
- Building with Grails
- Building with Bazel
- Building with Flutter
- Building with HarmonyOS
- Running Docker Commands to Operate Images
- Generating a Unit Test Report
- Customizing a Build Environment
- Using a Custom Build Environment
- Downloading a Software Package from Release Repos
- Uploading a Software Package to Release Repos
- Uploading Files to OBS
- Configuring Parameters
- Configuring Schedules
- Configuring Roles and Permissions
- Configuring Notifications
- Running a Build Task
- Viewing a Build Task
- Managing Build Tasks
- Querying Audit Logs
- References
- Old User Guide
Best Practices
- Creating a Docker Image with a Maven Artifact and Pushing the Image to SWR (Built-in Executors, GUI)
- Building with Maven and Uploading the Software Package to the Self-hosted Repo (Built-in Executors, GUI)
- Building with Maven to Generate a Private Dependency for Another Build (Built-in Executors, GUI)
- Building with npm and Uploading the Software Package to the Release Repo (Built-in Executors, GUI)
- Building with Maven (Custom Executors, GUI)
- Building with Maven, Uploading the Software Package, and Pushing the Image to SWR (Built-in Executors, Code)
- Running a Multi-Task Maven Build Project (Built-in Executors, Code)
- Using the File from the Self-hosted Repo to Build with Maven and Uploading the Resulting Software Package (Built-in Executors, GUI)
- Running a Build Task on a Custom Environment (Built-in Executors, GUI)
API Reference
- Before You Start
- API Overview
- Calling APIs
Task APIs
- Querying Build History in a Specified Period
- Downloading the Keystore File
- Viewing Task Status
- Querying Build Tasks in a Project
- Querying the Latest Successful Build with a Specified Code Repository
- Querying Details of a Build Record
- Querying Success Rate of a Build Task in a Specified Period
- Downloading All Build Logs
- Downloading Logs of Build Actions
- Obtaining Information About Build Records
- Obtaining Details About Build Results
- Stopping a Build Task
- Deleting a Build Task
- Disabling a Build Task
- Restoring a Build Task
- Updating a Build Task
- Querying a Build Template
- Creating a Build Template
- Deleting a Build Template
- Querying Notifications
- Updating Notifications
- Canceling Notifications
- Obtaining Build Task Details
- Downloading Real-time Build Logs
- Obtaining Build Records of a Task
- CodeArts Build (Unavailable Soon)
- Application Examples
- Appendix
- Change History
General
- Can I Run a Build Task with a Specific Server or Server Configuration?
- Why Are the Required Project Files Not Found During Builds?
- Files Not Found During Software Package Upload
- Why Am I Prompted that My Permissions Are Insufficient When Running a Build Task?
- Why Am I Prompted that the Build Task Does Not Exist When Calling It Through a Pipeline?
- Why Is My Task Stopped?
- How Do I Migrate Common Java Projects Created with Eclipse to the Cloud?
- Service Endpoint Did Not Exist
- Incomplete JAR Due to Parallel Build Tasks
- How Do I Resolve the Error Occurred When Pulling the Sub-module During My Build?
- How Do I Fix the Submodules Checkout Error Due to a Failure to Obtain Its Revision?
- Why Are the Submodules Not Being Pulled During My Build?
Maven Builds
- What Can I Do If License Check Fails?
- Failed to Upload a Package Using the maven deploy Command
- How Do I Deal With the Missing POM File?
- How Do I Deal With the Missing Package or Symbol?
- Using the exec-maven-plugin Extension for Maven and NPM Hybrid Builds
- How Do I Fix the Errors Related to References Among Multiple Child and Parent Projects?
- How Do I Configure and Clear the Cache for a Maven Build?
- How Do I Find the Correct Build Package Path?
- How Do I Use jib-maven-plugin to Build a Maven Project and Create an Image?
- Why Is the New Package Still Built from the Old Code Even After the Code Has Been Updated?
- Why Is My Download of Maven Components Slow?
Android Builds
- How Do I Deal With the Unstable Jcenter () Configured for a Project?
- What Should I Do If an Error Occurs During the Lint Check and the Task Stops?
- What Should I Do When Dependency com.android.tools.build:gradle:3.0.1 Cannot Be Downloaded?
- Why Am I Seeing the Error Message "Javadoc generation failed"?
- Why Am I Seeing the Error Message "Could not find method google()"?
- What Can I Do If the Gradle Version Is Too Early?
- How Do I Fix the Android APK Signing Failure?
- Using Gradle for Build
npm Builds
- Why Am I Seeing the Error Message "JavaScript heap out of memory"?
- Why Am I Seeing the Error Message "enoent ENOENT: no such file or directory"?
- Why Am I Seeing the Error Message "Module not found: Error: Can't resolve ..."?
- Why Did My Build Fail Without Displaying Any Errors?
- Why Am I Seeing the Error Message "npm cb() never called"?
- Why Am I Seeing the Error Message "gyp ERR!"? stack Error: EACCES: permission denied
- Why Am I Seeing the Error Message "eslint: error 'CLODOP' is not defined"?
- How Do I Fix the node-sass Download Failure?
- Why Am I Seeing the Error Message "error: Could Not Write Config File"?
- Why Does It Take Long to Install Dependencies and Build?
- What Should I Do When the Dependency Version Cannot Be Found?
Images
- Failed to Create an Image Using Dockerfile
- Failed to Push Images to SWR
- How Do I Resolve the Image Pull Failure During a Build Task?
- No Permission to Pull Images When SWR Public Images Are Used
- Failed to Log In to the Image Repository
- How Do I Push an Image to Other Tenants?
- Pulling Docker Hub Images Times Out or Exceeds the Max. Attempts
General
- Videos
On this page
Show all
You have registered with Huawei Cloud and completed real-name authentication. If you do not have a HUAWEI ID yet, follow these steps to create one:
- Visit Huawei Cloud official website.
- Click Sign Up and create your account as instructed.
Once your account is created, the system automatically redirects you to your personal information page.
- Complete individual or enterprise real-name authentication. For details, see Real-Name Authentication.
For details, see Purchasing CodeArts.
