Updated on 2025-07-31 GMT+08:00
Configuring Notifications
Notifications can be set at the system project, service project, and task levels. You can set notification modes for the code check task event types as required. The navigation paths are as follows:
- Service project level: Go to the project details page, and choose Code > Check > Config Center > Notifications.
- Task level: Go to the task details page and choose Settings > Notifications. This section uses the task-level notification settings as an example to describe how to enable and disable notifications.
- Access CodeArts Check.
- Go to the task page. In the task list, click a task name.
- On the task details page, choose Settings > Notifications.
- Enable or disable the notification of an event type as required.
- If Notify is enabled, event notifications will be sent to specific members of current project.
- If Email is enabled, emails will be sent to specific members of current project.
Parent topic: Configuring a Task
