Updated on 2025-07-25 GMT+08:00
Configuring Protected Tags for a Repository Group
You can configure protected tag rules for all repositories in a repository group. Before the configuration, view Constraints and configure protected tag rules for the repository groups by referring to Configuring Protected Tag Rules for a Repository Group.
Table 1 Constraints on configuring protected tags
Item
Permission constraint
Repository group members who have the set permission for repository groups can configure permissions on this page. For details, see Configuring a Repository Group's Permissions. Repository group members can only view this page.
Function constraints
  • Only one tag rule can be created for a tag. Otherwise, an error message is displayed, indicating that the protected tag name has already been used.
  • If you select Inherit from project, the settings of the project will be used and cannot be changed.
  • If Force inherit is selected, all child repository groups and repositories in the repository group will use the following settings and cannot be changed.
  1. Go to the details page of the repository group Test_Group to be configured, choose Settings > Policy Settings > Protected Branches, and click Create Protected Tag.
  2. If you do not select this option, see 2.
