- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Basic Configurations/
Process Management/
Incident Handling Process/
Managing Incident Categories
- Log in to COC.
- In the navigation pane, choose Basic Configurations > Process Management. On the displayed page, click Incident Category. The incident categories preset in the system are displayed on this page and cannot be edited or deleted.
Figure 1 Incident categories
- If you do not use a preset incidence category, you can disable it. To add an incident category, click Create Incident Category. After the incident category is added, you can view the latest enumerated values of Incident Category on the page for creating an incident ticket on the Incidents page.
Figure 2 Creating an incident category
Parent topic: Incident Handling Process
