- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Basic Configurations/
SLA Management/
Managing SLA Records
Viewing SLA Records
- Log in to COC.
- In the navigation pane on the left, choose Basic Configurations > SLA Management. Click the SLA-based Tickets tab.
Figure 1 Querying SLA records
- Click the search box. The search criteria list is displayed. Select search criteria, enter values, and press Enter to search for data. You can click the refresh icon next to the search box to refresh the data and configure the fields to be displayed in the list.
- Click the value in the SLA column to view the corresponding SLA template.
- Click a ticket ID in the Ticket ID column or click View Details in the Operation column to view the SLA record details.
Figure 2 Querying SLA record details
- The SLA Status column in the SLA Information table on the SLA Record Details page is strongly associated with the SLA rule configured during SLA template creation. If a service ticket status keeps for a duration that exceeds the specified duration set in the SLA rule, the status automatically changes to Has Broken.
- Duration is closely related to the status change of the ticket.
Parent topic: SLA Management
