Overview
With the transformation from traditional IT infrastructure O&M to cloud service O&M, traditional O&M methods face challenges such as complex inter-service invoking, fast application iteration, massive O&M objects, and complex non-linearity systems. Service downtime will bring huge economic losses and reputational damage to the company.
Chaos engineering is introduced to the O&M process. Through periodic simulation, system weaknesses (such as software bugs, solution design defects, and fault recovery process points) can be identified before problems occur on the live network, and system availability problems can be detected and resolved in a timely manner, continuously improve application resilience and build O&M confidence. For unavoidable scenarios (such as hardware faults, abnormal server power-off, and network device board faults), formulate a contingency plan for quick fault recovery in advance.
COC allows you to perform automatic chaos drills covering from risk identification, emergency plan management, fault injection, and review and improvement. Based on years of best practices of Huawei Cloud SRE in chaos drills, customers can proactively identify, mitigate, and verify risks of cloud applications, continuously improving the resilience of cloud applications.
Chaos Drill Function Introduction Video
Image and Disruptor Version Support Statement
Currently, the chaos drill feature supports probe attack objects such as Elastic Cloud Servers (ECSs), FlexusL instances, and Bare Metal Servers (BMSs), and provides corresponding resource and network disruptors for you to drill. Probe disruptors include disruptors for practicing, host resources, host processes, and host network modules. By integrating disruptor modules and functions, you can accurately simulate faults in the actual environment and identify system availability issues as early as possible, continuously improving application resilience.
The following table lists the ECSs, FlexusL, and BMSs image versions and supported probe tools.
CentOS 6.10 images and earlier versions do not support some probe disruptors because the system does not have the shared libraries (GLIBC_2.14 and GLIBCXX_3.4.15) required for running corresponding probe packages.
Table 1 lists the probe disruptors supported by each ECS image version.
Disruptor |
Supported Image Version |
Description |
Disruptors for practicing |
Qualifying practice |
CentOS 7.2, CentOS 7.6, CentOS 7.9, CentOS 8.2, Ubuntu 16.04, Ubuntu 18.04, Ubuntu 20.04, Ubuntu 22.04, EulerOS 2.2, EulerOS 2.5, EulerOS 2.9, EulerOS 2.10, Debian 8.2.0, Debian 8.8.0, Debian 9.0.0, Debian 11.1.0, and Huawei Cloud EulerOS 2.0 |
Host resources |
CPU usage increase |
Memory usage increase |
Disk usage increase |
Disk I/O pressure increase |
Host process |
Process ID exhaustion |
The process IDs of the EulerOS image are used up. The protection mechanism may be triggered, causing the kernel to restart. As a result, the drill fails. |
Killing a process/Continuously killing a process |
Host network |
Network latency |
CentOS 7.2, CentOS 7.6, CentOS 7.9, Ubuntu 16.04, Ubuntu 18.04, Ubuntu 20.04, Ubuntu 22.04, EulerOS 2.2, EulerOS 2.5, EulerOS 2.9, EulerOS 2.10, Debian 8.2.0, Debian 8.8.0, Debian 9.0.0, Debian 11.1.0, and Huawei Cloud EulerOS 2.0 |
Network packet loss |
Network error packets |
Duplicate packets |
Network packet disorder |
Network disconnection |
NIC break-down |
If the NIC becomes faulty, the UniAgent may go offline. As a result, the UniAgent information cannot be received, and the page fails to be displayed. |
DNS tempering |
Port occupation |
Server disconnection |
If the server becomes fault, the UniAgent may go offline. As a result, the UniAgent information cannot be received, and the page fails to be displayed. |
NIC bandwidth limiting |
Connection exhaustion |
Table 2 lists the probe disruptors supported by each BMS image version.
Disruptor |
CentOS 7.3, CentOS 7.9, Ubuntu 16, Ubuntu 1804, and EulerOS 2.3 |
Host resources |
Host process |
CentOS 7.4, CentOS 7.9, Ubuntu 16, Ubuntu 1804, and EulerOS 2.3 |
Host network |
Network latency |
Duplicate packets |
NIC break-down |
DNS tempering |
CentOS 6.9, CentOS 7.9, Ubuntu 16, Ubuntu 1804, EulerOS 2.3, and EulerOS 2.9 |
Port occupation |
CentOS 6.9, CentOS 7.4, CentOS 7.9, Ubuntu 16.04, Ubuntu 18.04, EulerOS 2.3, and EulerOS 2.9 |
Table 3 lists the probe disruptors supported by each FlexusL image.
Disruptor |
CentOS 7.2, CentOS 8.2, Ubuntu 16.04, Ubuntu 22.04, EulerOS 2.0, Debian 8.2, and Debian 11.1.0 |
Host resources |
Host process |
Host network |
Network latency |
CentOS 7.2, Ubuntu 16.04, Ubuntu 22.04, EulerOS 2.0, Debian 8.2, and Debian 11.1.0 |
Duplicate packets |
NIC break-down |
DNS tempering |
Port occupation |
