Batch Reinstalling OSs of ECSs
COC provides unified operations on ECSs. You can reinstall the OSs of ECSs one by one or in batches.
Precautions
- If any instance is running, you need to stop the instance before performing this operation.
- If all instances are stopped, you can submit the execution task.
- If any service ticket (for example, restart service ticket) is being executed on the selected instance, the current operation cannot be performed. Wait until the existing service ticket is complete and try again.
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Batch Resource Operations.
- On the displayed page, choose the Elastic Cloud Server (ECS) tab and click Reinstall OSs.
- Click Add and configure the parameters on the Select Instance dialog box.
Table 1 Instance parameters Parameter
Example Value
Selection Method
Select an instance selection method.
- Manual Selection: Manually select an instance based on Enterprise Project, View Type, Resource Type, Region, and Target Instance.
- Select All: Automatically select all instances based on Enterprise Project, View Type, Resource Type, Region, and Target Instance.
Manual Selection
Enterprise Project
Select an enterprise project from the drop-down list. You can choose All.
All
View Type
Select a view type.
- CloudCMDB resources: Select an instance from the resource list.
- CloudCMDB application groups: Select an instance from the application group list.
CloudCMDB resources
Resource Type
The default value is used and cannot be changed.
ECS
Region
Select a region from the drop-down list.
CN-Hong Kong
Target Instance
Set filter criteria in the filter box and select the filtered instances manually or automatically.
- Set parameters for Batch Policy, Suspension Policy, Stop ECS, and Timeout Interval.
- Batch Policy: Select Automatic, Manual, or No Batch.
- Automatic: The selected instances to be executed are automatically divided into multiple batches based on the preset rule.
- Manual: You can manually create multiple batches and add instances to each batch as required.
- No Batch: All instances will be executed in the same batch.
- Suspension Policy:
- You can set the execution success rate. When the number of failed hosts reaches the number failed ones that are calculated based on the execution success rate, the service ticket status becomes abnormal and the service ticket stops being executed.
- The success rate ranges from 0 to 100 and supports accuracy up to one decimal place.
- Select Stop now under Stop ECS. When the service ticket starts to be executed, the instances that are not stopped will be stopped automatically.
- Timeout Interval: Value range: 1 to 1800, in seconds.
- Set Login Mode.
- Password: You can use the original ECS password or enter a new one.
- Key pair: You can select a key pair in Key Pair Service.
- Reset password: Before logging in to the ECS, reset the password.
- Click OK to go to the Confirm Execution page. Click OK to start the execution.
- Perform the following operations to check whether a service ticket execution is complete.
- For the service tickets that are being executed:
- If you want to pause the next batch when the current batch is executed, click Pause in the upper right corner.
- If you want to continue the paused batch, click Continue in the upper right corner.
- If you want to stop the service ticket that is about to be executed or is abnormal, click Forcibly End.
- For the service tickets that are executed:
- If some or all instance tasks in the service tickets are executed abnormally:
- Click the Abnormal tab in the Execution Information area. Locate an abnormal batch and click Retry in the Operation column.
- Select an abnormal batch and click Batch Retry above the instance to re-execute all abnormal tasks in the current batch.
- Click the Abnormal tab in the Execution Information area. Locate an abnormal batch and click Cancel in the Operation column.
- Select an abnormal batch and click Batch Cancel above the instance to cancel all abnormal tasks in the current batch.
- If all instance tasks in the service tickets are executed successfully, no more operation is needed.
