Help Center/ Cloud Operations Center/ User Guide/ Automated O&M/ Patch Management/ Viewing Patch Scan and Repair Details
Updated on 2025-08-08 GMT+08:00
The results of patch scan and patch repair are also called patch compliance reports. To view details about a patch in the compliance report, perform operations in this section.
Precautions
The patch compliance report will only retain the most recent scan or repair record.
  1. Log in to COC.
  2. In the navigation pane on the left, choose Resource O&M > Automated O&M.
  3. In the Routine O&M area, click Patch Management.
  4. On the Patch Scanning tab page, select the resource type of the instance whose patch needs to be viewed.
    By default, ECS is selected.
  5. Locate the target instance and click Summary in the Operation column.
    Status description:
    • Installed: The patch complies with the patch baseline, has been installed on an ECS, and no update is available.
    • Non-baseline Patches Installed: The patch is not compliant with the patch baseline but has been installed on an ECS.
    • Installed-to be Restarted: The patch has been repaired, and can take effect only after the ECS is restarted.
    • Installed Rejected: The rejected patch defined in the abnormal patches of a patch baseline. This patch will not be repaired even if it is compliant with the patch baseline.
    • Pending Repair: The patch complies with the baseline, but the patch version is earlier than the baseline version.
    • Patch Repair Failed: The patch repair fails.
