Viewing a Patch Service Ticket
After a patch scanning or repair task is executed, a patch service ticket record is generated to record the patch execution result. To monitor and record the execution objects and results of a patch scan and repair task, you can use the patch service ticket function.
Viewing the Execution Records of a Patch Service Ticket
- Log in to COC.
- In the navigation pane, choose Task Management > Execution Records.
- Click the Patch Tickets tab.
- Click a patch ID.
- Perform the following operations based on the service ticket status:
- Abnormal: Click Forcibly End in the upper right corner to end the service ticket.
- Executing: Click Pause or Forcibly End in the upper right corner to pause or terminate the service ticket.
- Paused: Click Continue or Forcibly End in the upper right corner to continue or terminate the service ticket.
- Completed: Click Compliance Report in the upper right corner to view the patch service ticket result.
