- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Security Overview
You can view the security monitoring information from SecMaster.
View the security monitoring information provided by SecMaster on COC.
- Log in to COC.
- On the Overview page of COC, you can view the security monitoring information provided by SecMaster.
Figure 1 Security monitoring information from SecMaster
- Click Custom Dashboard to set the charts to display.
Figure 2 Customizing security monitoring dashboard
Parent topic: Overview
